Thread: rear door wont open.
    Regular Member jun's Avatar
    burton-on-trent
    Unhappy rear door wont open.
    Im havin problem with one of my rear doors.
    Some times the door will open and other times i wont.
    The pin only pops up half way when it doesnt open.
    Any ideas?
    How easy is it to remove the door card?
    Regular Member Robward27's Avatar
    Witham
    If you have electric rear windows its pretty easy most pops off round bottom edge 2 screws in main handle. Top is clipped on also. If you have manual windows you need to get a special tool or make a plate up to remove the circlip from the winder between the winder and the door card.
    http://www.justoffbase.co.uk/Window-...580-Draper-WWT
    there may be few more screws but dont think so took mine off few years ago.
    Regular Member poves's Avatar
    lancashire
    screws in bottom of door panel , a couple behind the grab handle - then it should pop off , then cable clips off the grab handle release from rear.
    If the lock is dodgy I have one for sale .
    As rob says - if it's got a winder handle you need to remove the circlip.
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Best way to remove circlip is to push in the door trim a bit and look behind the handle you should be able too see the circlip. slip a bit of rag behind the handle and pull it along the door trim so it catches the open ends of the clip and it should pop of HTH
    burton-on-trent
    Its got electric windows.
    il have alook in a min. and let u no the out come!
    cheers guys.
    burton-on-trent
    hmm took it off for alook but cant seem to see nothin wrong?
    but its workin ok for now.
    lancashire
    The push stub was probably fouling on the door trim , easyfix
  1. rear door wont open
    By andrew smith in forum Bodywork & Interior
    Last Post: 7th January 2012, 17:59
  2. Rear door wont open
    By fingers66 in forum Bodywork & Interior
    Last Post: 11th October 2011, 15:06
  3. Rear door wont open
    By Jeffb in forum Bodywork & Interior
    Last Post: 13th February 2011, 21:06
  4. door wont open
    Last Post: 10th March 2010, 20:31
  5. My rear door wont open
    By rhodod in forum Vectra C / Signum Troubleshooting
    Last Post: 4th December 2008, 22:34
vectra c rear door wont open site:www.vectra-c.com
