View Poll Results: how big would you go
Voters
29. You may not vote on this poll
  • 225 / 40 / 18
    4 13.79%
  • 235 / 40 / 18
    7 24.14%
  • 245 / 40 / 18
    11 37.93%
  • 255 / 40 / 18
    7 24.14%
Results 1 to 10 of 17
Thread: i needed tyers so what do you think i put on
    member of the smoke patrol 230bhp+
    Default i needed tyers so what do you think i put on
    come on iv gone and done it but what did you think i did
    Regular Member swainey's Avatar
    Newtown Powys
    245s
    Quote Originally Posted by swainey View Post
    245s
    hell have you seen my car
    iv got to say the drive is so smooth compared to the 225 and neck breaking in the corners
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I think you should have had 45/18's on your list as I dont think 40/18 is the right size. Not on mine anyway
    What J are your alloys?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    For 245's u need 8.5j I would have thought or at least 8J
    Regular Member cameraman's Avatar
    Leicester
    225/45 18 is the normal size put on the Vec, but if you're wider then a 40 profile is fine 245/40 18 is what's on the Insignia iirc
    my wheels are 8 j
    as for the size there spot on for the 215/50/17 but the the 245/40/18 but the 245 are wider so my speedo is still spot on to
    215/50/17 elite spec revs per mile is 792
    245/40/18 elite spec revs per mile is 784
    so my speedo is going to be 0.6% slow so as you can see its so very very close on the speedo
    http://www.miata.net/garage/tirecalc.html
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Yes but what width is the alloy (J)?
    245 should not be fitted to a 7J or 7.5J, still a bit close on a 8J
    Edit: seems we posted at the same time lol
    Northampton
    Engine : A20DTH
    Mileage : 88000
    the ideal width for a 245 is 8.5 I think but you can get away with it on a 8j which would be the minimum width
    I have 235/45/18's on my 8J's and its spot on the recommendation for width.
    As for using a tyre calculator its fine to get a rough idea, but it also depends on the setting in the ECU for tyre sizes.
    Using my satnav as a reference my speedo is spot on, but I did change the settings in the ECU several times to get the correct reading
    And yes I agree with you as regards grip. I cannot get mine to lose any when throwing round bends. Big difference to the 215 rubber bands fitted as standard
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quick check here http://www.toyo.co.uk/productdetail....s&product_id=2 says 245/40's should be fitted to minimum 8J to max 9.5
    I think I would go for at least a 8.5J for this size
  1. Tyers for 18s
    By franko in forum Styling
    Last Post: 19th January 2013, 12:54
  2. where to get cheap tyers?????
    By bangty 1 in forum Vectra C / Signum Car Chat
    Last Post: 17th October 2010, 21:11
  3. falken tyers
    By swainey in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2009, 00:41
  4. 17" GSi With NEW Eagle Tyers
    By andymagee1982 in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 23rd February 2009, 17:52
  5. vauxhall tyers
    By yorkshireborn in forum Vectra C / Signum Car Chat
    Last Post: 25th October 2006, 14:43
