Results 1 to 10 of 11
Thread: Please help me
    Near Warrington
    Default Please help me
    HELLO EVERYBODY PLEASE HELP ME I OWN A 53 PLATE 3.2 GSI WITH 70000 GENIUNE MILES ON THE CLOCK.RIGHT HERE WE GO:THE CAR STARTS FINE AND RUN WELL FROM COLD BUT AFTER SAY 15 MINS OF RUNNING THE ENGINE CUTS OUT DEAD AND WILL NOT RESTART UNTIL ITS COOLED DOWN AND THEN WILL RUN FINE UNTIL IT GETS HOT AGAIN?ANY FEEDBACK OR HELP IS MUCH APPRECIATED....THANKS ALOT BRI..
    Jul 2006
    Mexico
    The only safe way to go is that you get the fault codes read....that for starters.
    BTW hit CAPS LOCK for us
    Near Warrington
    Thanks for your reply my mate its booked in tomorrow for a check up (if i make it that is)
    Mileage : 000
    Could be a sensor for the tempreture giveing the wrong info" to the ECU.
    Near Warrington
    hi do you think this would shut the engine dead?its as though you,ve turned the key off..
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    check your thermostat is not locked shut m8
    Near Warrington
    Thanks a lot i,m slowly working through the basics and then i,ll have peice of mind before it goes into an independant specialist tomoorow
    Regular Member poves's Avatar
    lancashire
    Like ed say's , sounds like coolant temp sensor .
    Or some other sensor .
    Regular Member CDXI_2003_AUS's Avatar
    Melbourne, Australia
    I would check the fault codes yourself first before payin the dealers alot of money to tell you what you can find out for free!
    Regular Member markd3925's Avatar
    Eindhoven
    Vehicle : Vectra GTS
    sounds like a crankshaft sensor fault, could be a temp sensor but would expect that to flood it rather than stop it dead
