Thread: Are reversing sensors affected by tow bar ?
    Bournemouth
    Default Are reversing sensors affected by tow bar ?
    Does anyone know whether fitting a tow bar will affect the reversing sensors in the bumper ?
    Regular Member davree's Avatar
    Warton
    Vehicle : Insignia
    Engine : 2.0 CDTI (160)
    Year : 2010
    Mileage : 26000
    I think they can be affected if it is a fixed towbar!!
    Regular Member Teefin's Avatar
    SW Scotland
    The answer is yes they can depending on the type of bar fitted and where the sensors are. If you have a switch to turn off the sensors then you can live with it.
    Regular Member mark the hat's Avatar
    Jan 2008
    manchester
    Default .
    fitted my own sensors as the how to,and had a tow bar/ball (fixed) fitted at a later date.........no problem what-so-ever hope this helps
    cheers mark
    [Ex]Admin Duncan's Avatar
    If you have the Vx factory fit sensors and fit a towbar with the Vx electrics module, then the reverse sensors will automatically be disabled when you plug into the towbar.
    As above, without anything attached the towbar shouldn't, but 'may' be sensed - all depending on how the towbar has been attached and how they sensors have been fitted if they're aftermarket.
    Regular Member kiwigolfer's Avatar
    Port Glasgow
    Vehicle : Insignia 2.0
    Fitted the Cisbo sensors with the Towbar on an 07 Sri and used the sensor locations on the inside of the bumper and no Poblems.
    had to drop the towbar to get the bumper off
  1. reversing sensors
    By redo in forum Electrical & ICE (including SatNav)
    Last Post: 8th May 2012, 19:27
  2. reversing sensors
    By markj23 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd October 2011, 21:10
  3. reversing sensors HELP PLEASE
    By SRIRob in forum Styling
    Last Post: 20th January 2010, 14:43
  4. reversing sensors off e-bay £16.99 + pp
    By new vectra owner in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2007, 20:12
  5. which reversing sensors please?
    By wardy in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2007, 21:48
