You will loose radio code, not sure about anything else!!
You won't lose radio code, I didn't! Been off loads of times for hours too!
You'll have to reprogramme windows though to be auto but that's easy.
My battery was off for 5 mins and I lost the radio code on mine!!
How do you re-programme windows?? Is it a case of just wind all the way down and then back up again. I have got a feeling this was not done when my alternator died!!
yes but keep button held in the up position till you hear a beep
Swainey mines an 06 nav, so you should be ok, the code is held in the ecu so will be fine, there are other threads on the subject.
i disconected the battery and the light is still on
If you know someone with a u480 code reader or similar, they can probably kill the light by clearing the fault code. If it is still lit after being killed, then the fault is still there. Did you try putting the original bulbs back in?
no but its worth a go
I don't know what else to suggest then mate really apart from above! Hope you get it sorted.
