Results 1 to 2 of 2
Thread: clogged inlet manifold.
    southampton
    Default clogged inlet manifold.
    Hi ive got a 2003 2.2dti veccy and I took the top half of my inlet manifold off to clean my boost sensor dur to another problem but when i took it off i found the inlet manifold to be caked in a black sorta sludge. Is this bad? Do I need to do anything about it or is it normal? thanks
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Hi alex yes this is entirelly normal . give it clean out with a carb cleaner spray, block of the vacuum input whilest doing it , also if it is as bad as you say you might as well clean your egr valve as well because if one is then other will cruded up as well
  1. new inlet manifold
    By redross555 in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2011, 17:28
  2. 1.9 150 Inlet Manifold..
    By GazVXLINE170 in forum Engine & Drivetrain
    Last Post: 18th July 2011, 20:29
  3. Inlet manifold
    By gaz1965 in forum Vectra C / Signum Car Chat
    Last Post: 17th April 2011, 19:50
  4. New inlet manifold,,,,new car !!!!
    By collyb in forum Engine & Drivetrain
    Last Post: 15th April 2011, 13:10
  5. Inlet manifold
    By the-wizard in forum Vectra C / Signum Car Chat
    Last Post: 19th January 2010, 17:26
