Results 1 to 10 of 11
Thread: wheels stuck!
    southampton
    Default wheels stuck!
    I know it may sound trival but ive been trying to get my wheels off all day and two of them are stuck solid, and yes all the bolts are out! haha Has anybody got any solutions to get them off. Ive tried kicking, hammering, pulling! but no luck! Any help will be appreciated.
    Regular Member andymagee1982's Avatar
    May 2008
    Widnes.
    Lump Hammer????
    But I have discression (spelling)
    Regular Member gromit's Avatar
    Cumbernauld
    Kick one part then turn wheel then kick then turn and repeat and you should start to get a wee bit of movement. Better go get you BIG boots on. Either that or a block of wood and a large hammer and do the same from behind the wheel. Thats what i've done in the past.
    lanark
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    i would have suggested hitting the back of the wheel with a rubber hammer but i take it you have tried something like that
    maybe a spray of wd40 being careful to avoid the brakes
    Regular Member davree's Avatar
    Warton
    Vehicle : Insignia
    Engine : 2.0 CDTI (160)
    Year : 2010
    Mileage : 26000
    Jack the car up!!
    Sorry couldn't resist, as above try a lump hammer but be careful not to damage anything!!
    Regular Member Blagmeister's Avatar
    Warks
    I wouldn't try bashing your alloys as it may damage it.
    Go get a long piece of timber and stick one end behind the back of the wheel and brace it against a bit of chassis, then just lever it off. No impact, just fulcrums and levers
    The longer the bit of timber the better.
    HTH
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    They corrode to the centre hub spigot and face. When you get them off by hammering, kicking, swearing, levering etc, put some copper grease on these areas to prevent it happening again.
    Regular Member poves's Avatar
    lancashire
    Loosen all the wheel nuts a bit and rock the car violently lol .
    Regular Member nicj's Avatar
    northumberland
    Vehicle : Cdti150
    Trim : Sri
    Year : 06
    Quote Originally Posted by Blagmeister View Post
    HTH
    but you should be fine giving the wood a whack turn the wheel also .Thats how i got taught and it worked for me never damaged a wheel
    Warks
    Yes indeedy to both the last two replies. The copper slip stops it from sticking again and because its the wood you are bashing and not the wheel, [plus the wheel rotation], you stand a good chance of not jiggering up your rims.
  1. how u stuck urz on
    By vectraross in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2012, 18:24
  2. Annoying squeak and wheels stuck on!!!
    By MickAP in forum Vectra C / Signum Car Chat
    Last Post: 7th September 2011, 15:00
  3. Swirl Flap Stuck or Not Stuck ??
    By nibblitz in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2010, 17:57
  4. Stuck Rear Wheels
    By AdeyCorp in forum Suspension, Wheels & Brakes
    Last Post: 24th June 2010, 19:15
  5. stuck with her
    By gaz 1982 in forum Vectra C / Signum Car Chat
    Last Post: 30th June 2007, 14:42
