Page 1 of 21 12311 ... LastLast
Results 1 to 10 of 204
Thread: Swirl flaps Linkage Rod
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Default Swirl flaps Linkage Rod
    So - just looked at mine this AM (and another CDTI) and the rod has come out of the swirl flaps top... - car is a 2005 CDTI (150).
    Car runs fine, very well actually, so is this a problem..?
    leave it out or try and fiddle about and put it back in...?
    Do the swirl flaps have to be in a certain position when you put the rod back in?
    Regular Member willoftoon's Avatar
    FOREST HALL NEWCASTLE ,,,,,OR DECKHAM ,, ON SUNDAYS .. DINNER TIME MAMMY,S
    same as mine if its out it has rounded so will just pop back ou tagain sure some 1 did a how 2 using o rings
    Middlesex
    Trim : SRI
    Mileage : 100k
    Just spent 45 mins trying to get the bl00y thing back in!!! grr - cant get it close!!!
    All swirlflaps are free and movable (except no 3 which I believe is the motorised one).... so just need to get a new linkage bar then I guess if they wear... ?
    Any tips on putting it back on?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    http://forum.vectra-c.com/showthread.php?t=33511
    try this for the repair, but i could'nt find these exact washers so i got blanks and drilled + glued them and its still ok , must av been 18 mths since !! its fiddly to remove and replace but worth it.
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by the-wizard View Post
    Ah Great!! nice one.
    It certainly isnt effecting the running of the car - running like a dream since I cleaned the EGR..
    So on this fix you file down the bottom of the studs on the rail - or the sides, dont quote get that??
    And where do you stick the washers - at the bottom of the studs, or do you put the stud through the washer??
    thanks in advance
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    ok ,you remove the rod and just clean up the bottoms where the rod sits onto the flap balls, its only to give a clean surface to super glue the washers to, i put a large piece of sand paper on a flat surface and put the rod onto it to rub all four black bits at the same time to achieve an even surface to all at the same time, i then drilled the blank washers to aprox 6 or 7 mm i think then glued them to all four parts of the rod giving them a top hat look!! (ie glue to where the arrows are pointing in the pic) when dry line up the ball discs and push fit the rod complete with the glued rubbers over the balls, this took a while cos they move and are tricky to line up x4 at once!
    (it does'nt matter if the holes in the rod have gone oval cos when the rubbers are on they will hold the rod onto the balls). and as an after thought thats the word i would use to explain the design, a load of the above.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    has this got the better of you ant? lol
    Middlesex
    Trim : SRI
    Mileage : 100k
    Bl00dy thing - tried for ages to put the rod back in - got fed up and gave up in the end lol
    Seems that once they wear its pointless anyway as they will just come back out...
    A
    Are you VXR Enough
    13 Post(s)
    wish id not said anything about this now mate lol
    Middlesex
    Trim : SRI
    Mileage : 100k
    hehe - i'm not going to worry to much about it until running is effected TBH..
  1. Swirl linkage advice please?
    By Gerdo3 in forum Engine & Drivetrain
    Last Post: 10th April 2012, 12:52
  2. Swirl Rod Linkage
    By bafoo in forum Vectra C / Signum Troubleshooting
    Last Post: 9th July 2010, 16:26
  3. EML was on now off...could it be swirl valve linkage
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 23rd March 2010, 09:14
  4. Swirl flap linkage fallen off but managed to bodge it! (I hope!)
    By jrwilshire2003 in forum Engine & Drivetrain
    Last Post: 22nd January 2010, 22:42
  5. Swirl Flap Linkage Rod 'Cheap' Fix
    Last Post: 1st April 2009, 20:58
vectra c swirl flaps linkage rod
