Results 1 to 3 of 3
Thread: Diesel Pump?
    Somerset
    Default Diesel Pump?
    Finally took my Vectra C DTI 2.0 into the dealers today, as i have the engine management light on and wanted the code read. Apparently they said it has 19 codes coming up! And they worked through and got it to 9 (without fitting parts? is that possible) and did an ECU update, but could not continue as they had other work on, so i collected the car.
    They said it looks like it is pointing towards the diesel pump? However the car is working fine, starts first time, no black smoke and drives really smooth, the only problem is i cant rev the engine past 2500 as the damn light on! Do you think this could be the problem? Gonna take it to another garage to get their opinion i think! Wish i had asked for the codes that come up!
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    If the car works fine, runs smooth it definitely ISN'T the diesel pump.
    First thing - try cleaning the MAF sensor and check the boost hoses.
    You can check for fault codes yourself:
    Step 1-press brake pedal and hold it
    Step 2-gas pedal the same
    Step 3-insert key and turn the ingition on
    Step 4-the emission light will flash if there is any fault stored in the car's ECU.
    Full Member
    Bristol
    If the eml is on it in limpmode. No acuaters and no turbo thats why it will not rev.
    Wher are located in somerset? I have a snap-on code reader.
  1. looking for diesel pump x20dtl
    By C-Owner in forum General Chat
    Last Post: 6th June 2012, 19:17
  2. Diesel pump
    By ads3 in forum Engine & Drivetrain
    Last Post: 9th June 2011, 18:57
  3. Diesel pump???
    By pasty steve in forum Engine & Drivetrain
    Last Post: 15th September 2010, 15:34
  4. Need me a diesel pump!!!
    By cov in forum Engine & Drivetrain
    Last Post: 20th January 2009, 18:42
  5. diesel pump!
    By littlesxi in forum Diesel Engine related
    Last Post: 29th January 2008, 01:15
