Thread: Clutch noise?
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    Default Clutch noise?
    guys last night while drivin i noticed a stange noise/feeling on the clutch pedal. i could only notice it while stationary. it would happen if the car was in neutral and i pressed the pedal to put it into gear. you would notice a almost chugging noise and the pedal would maybe slightly vibrate but hardly anything. only thing was it did go away for a bit then came back. any ideas? thing is i dont drive the car as much and wondering if this has anything to do with it but will drive it again today and see what happens. annoying thing is that it has just come out of warrenty about 2 weeks ago would i have anything to stand on with regards to vx?
    northampton
    Dual mass flywheel
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    i would contact your local dealer,if you have FVSH then you have a god case,you may have to pay for the clutch though if you want a new one fitted,they may help but i would do it asap,you may need to phone vauxhall
    Regular Member Craig1985's Avatar
    harwich essex
    Quote Originally Posted by cars01 View Post
    Dual mass flywheel
    Wish i had a £1 for every time this was mentioned!
    Aug 2007
    Lisburn, N.Ireland
    well i went to vx as i was pickin up some other parts. when i got there it had pretty much stopped. the local mechanic came and had a look and said there was maybe a slight noise but to find out it would be a clutch out job so i asked if it could be because the car sits maybe it could be that. he said maybe but to keep an eye on it so ill do that and not worry in the mean time
  1. Clutch noise
    By byebyeitsagsi in forum Engine & Drivetrain
    Last Post: 29th April 2011, 10:25
  2. Clutch noise
    By benwalters82 in forum Engine & Drivetrain
    Last Post: 1st July 2010, 08:10
  3. noise on clutch
    By gasrac in forum Engine & Drivetrain
    Last Post: 24th May 2009, 18:39
  4. Noise on clutch
    By PeteRs in forum Vectra C / Signum Car Chat
    Last Post: 29th February 2008, 11:54
  5. Clutch Noise / Kit
    By robzc in forum Engine & Drivetrain
    Last Post: 23rd March 2007, 08:11
