Thread: Limp Mode Help Please.
    Vec-C Facebook Admin thegoldenbullet's Avatar
    Mar 2007
    Grimsby, Lincs.
    Default Limp Mode Help Please.
    On thursday the car went into limp mode on the way home for work, only for about 3 seconds, then flashed off and back to normal running. no probs.
    Friday morning to work does same thing, but fine afterwards and fine on way home. Been fine since.
    Is it possible that snow and ice build up on the grille would cause the limp mode to kick in?
    Russ
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Welcome to the club GB thats the i have a dti going in to limp mode club , answer to your question about ice is i would seriously doubt it , more than likely is the usual suspect,s :ie EGR valve, Boost sensor check your hoses from turbo to manifold via your intercooler , check your vacuum hose connectors for splits , do these last two first and work backwards i dont know the history of your car :ie what problem,s you have had before, but this should get you started .
    and still loving it
    Mar 2007
    Grimsby, Lincs.
    Quote Originally Posted by bobssignum View Post
    happened about 18 months ago mate on one journey. after that nothing until thursday/friday (3 occurances over them days) then nothing since.
    it only seems to be during extremely low weather/temperature, and or steep incline. and i think my radiator mounts need looking at! is that an easy self fix to tighten these?
    Engine : 2.0DTi
    Mileage : 73350
    Dont know about your rad mounts but what you have just said about cold weather and inclines makes me think you have a boost problem . I would take your boost sensor out and give it a clean with some carb cleaner spray, but check your hoses while you are there.
    and still loving it
    Mar 2007
    Grimsby, Lincs.
    nice one cheers
    Engine : 2.0DTi
    Mileage : 73350
    Any joy with the motor gb
    and still loving it
    Mar 2007
    Grimsby, Lincs.
    been working fine normally and on inclines. suspecting snow/ice had blocked air flow
    Apr 2009
    Durham
    Hi, having similar problem with 2.0 DTI, where is boost sensor so I can check that for fault/damage??
  1. Limp mode help
    By neill in forum Engine & Drivetrain
    Last Post: 20th March 2012, 19:53
  2. Limp mode or dead mode
    By JSYSH466Y in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 09:46
  3. Limp mode
    By dan1983 in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2008, 18:35
  4. Limp mode
    Last Post: 3rd July 2008, 10:34
  5. limp mode
    By vauxvec in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2008, 22:03
