Thread: head light bulbs
    Regular Member samngeorge1985's Avatar
    lanark scotland
    Default head light bulbs
    does any one know how to change headlight bulbs on a face-lift model, i hace bought a h i d conversion kit and im not to sure of how to fit it thanks george
    Belfast
    Take off cap, pull out old bulb, push in new one, refit cap.
    Regular Member Zark's Avatar
    Herts
    Quote Originally Posted by samngeorge1985 View Post
    there's a 'how to' and various other threads on here if you look (or try the 'search' button!)
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    easiest way mate, is to take off bumper (only 8 screws) you can then take out the actuall headlight unit makes it 100 times easier
    Regular Member Robbie69's Avatar
    The passenger side is easy just remove the washer bottle filler neck, it just pulls off. On the drivers side remove the airbox, undo clip on top pipe and pull out, it's held on with three rubber bungs. This will give you plenty of room to work. The back of the light just twists off!
    Good luck
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    to fit the hid kit honestly remove the bumper. get a friend to help you . only 4 screws under bonnet 2 in each wheel arch and 4 screws along the bottom plus 4 plastic rivit things then it come off. only 3 screws per headlight and they are off as well. just test the kit before you drill the caps on the back of the headlight. if al ok refit.
  1. whats going on with my new head light bulbs??
    By Mads in forum Electrical & ICE (including SatNav)
    Last Post: 18th April 2012, 23:44
  2. head light bulbs
    By johnnyg in forum Electrical & ICE (including SatNav)
    Last Post: 26th October 2007, 18:19
  3. help on head light bulbs
    By jonnye in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2007, 06:36
  4. Head Light Bulbs Changing
    By tash in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2007, 01:06
  5. Head Light Bulbs (which way up)?
    By vectrasri03 in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2006, 23:04
