Results 1 to 10 of 18
Thread: u480 diagnostic scanner problems
    Regular Member dan9895's Avatar
    Apr 2008
    exmouth devon
    Default u480 diagnostic scanner problems
    i have brought a u480 diagnostic scanner for my vectra 03 2.0 dti
    however i am unable to use it it keeps coming up linking error like its not connected to the car?? :S i have had major problems with this car is there any reason that the clip in the car under the ashtray wouldnt work? its not the unit tested on several types of car no other vectras though could it have anything to do with my aftermarket stereo any help would be massively appreciated thanks in advance
    Nottinghamshire
    Many fault scanners - including the u480 - seem to have a note similar to the following as part of their descriptions on a lot of websites that sell them:
    All European Vehicles 2001 - Current Year Petrol (OBD-2)
    All European Vehicles 2004 - Current Year Diesel (OBD-2)
    I recently bought the (more expensive) RAC scanner from Argos and similarly found that it doesn't work with my 2003 2.2 DTI but does work with a 2002 GSi and a 2008 1.9 CDTI.
    I'm not sure why this is - I think it may be something to do with the 2002-2004 diesels being partial-CAN instead of full-CAN or something. I am still looking for a fault scanner that will work for my car.
    Apr 2008
    exmouth devon
    Quote Originally Posted by James24 View Post
    thanks for your reply james that stops me going argos this weekend can anyone else tell use wht scanner will work on our cars?
    Apr 2008
    exmouth devon
    bump
    Regular Member Phil MC's Avatar
    Kirkie
    My U480 comes up with a link error if it isn't plugged in far enough.
    There are two power pins that stick out more than the others on the interface cable so that if it's not connected far enough on the U480 will power up but not be able to detect any software protocol.
    It's either this, or as suggested earlier, that it's just not compatible with this model, although I know the U480 can read about 3 or 4 different types of software?
    Phil
    Full Member Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    I've got one aswell, Used it on the astra estates and vans ie had at work, worked fine on 51 reg astra's, cannot see why it shouldnt work just aswell on your car, Unless its a half can bus, I have no idea when the half canbus came in though (it might have 2003) so You may need a canbus scanner..
    Apr 2008
    exmouth devon
    i think mine is half cn-bus is there a way of telling??
    phil : what vectra you using it on?
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Engine : 3.0 TDV6
    Mileage : 3023
    PM Sean (Big Sig) or Duncan, either of those two may be able to tell you, im not too sure but i think one way to tell is by the steering wheel controls but i might be wrong....
    Thinking about it i've got both types of scanner, and i lent Sean my scanner thats the same as yours and it didnt work on his car, so i lent him the canbus version and it worked a treat!!!
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    What canbus scanner was it pete ?
    If you have 3 buttons either side on steering wheel you will have half canbus if its scroll wheels its full
    Kirkie
    Quote Originally Posted by dan9895 View Post
    Mine is a half canbus 2004 1.9 CDTi 150 SRi and U480 is working good for me
  1. U480 Fault Code Scanner
    By Telboy in forum Vectra C / Signum Car Chat
    Last Post: 7th July 2011, 13:48
  2. U480 diagnostic Scanner, can engine be running when reading codes
    By wickedwillie in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2010, 11:58
  3. Engine Management Light, fault doesn't show on U480 scanner
    By petesaysblimey in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2009, 16:51
  4. Got a U480 canbus diagnostic scanner delivered today....
    By merikiito in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2009, 19:38
  5. U480 Scanner
    Last Post: 7th March 2008, 14:24
vectra c not connecting to diagnostic
lnking error u480
