Thread: Air conditioning problem!!!!!!!
    Dominican Republic
    Unhappy Air conditioning problem!!!!!!!
    I have a problem with the heating of the car does not work when I move the heater does not heat cold and always sounds something like a motor or a window that does not want to open ..
    it sounds like something inside the console and it will not be as cool air but does not heat very well.
    sound,, CLA CLA CLA
    when you move the button to the heating rings rioja pongon and if the cold does not sound as if moving leg rings and adjust the temperature setting is not kept cold ...
    who can help me ...
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    95 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Crikey, do you need heating in the Domincan Republic?? Sounds to me like either something stuck in the blades of the fan motor or the fan motor itself is Knackered.. Im sure someone who's experience a similar fault will be able to help you though
    Mileage : 000
    Have a read of this. Don,t know if it is any help to you.
    Dominican Republic
    Quote Originally Posted by Big-Pete View Post
    yep-- a litter,,,
    Dominican Republic
    this car uses air filter . inside...
    Dominican Republic
    This is not because this is easily damaged by heating and that is not used much here .. but when the glass front of clouds must be used ... and it is difficult to handle with glass cloudy.
    Dominican Republic
    and does not present any code
    Full Member spennny's Avatar
    Blantyre
    Come one, who can help the man with his problem
    Dominican Republic
    Mileage : 000
    That looks like the part I was making referance to. Look here to see where it is fitted to the heater.
    The screw at the back of the servo is a little awkward to get to. But there are only Two holding the servo onto the heater.
  1. air conditioning
    By marko1973 in forum Electrical & ICE (including SatNav)
    Last Post: 28th March 2011, 21:37
  2. Air conditioning problem
    By antchev in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2010, 10:44
  3. Weird Air Conditioning problem?
    By PhilDunford in forum Vectra C / Signum Troubleshooting
    Last Post: 8th June 2009, 15:02
  4. air conditioning fan??
    By alexander08 in forum Electrical & ICE (including SatNav)
    Last Post: 27th November 2008, 15:47
  5. Air conditioning
    By cbee101 in forum Vectra C / Signum Car Chat
    Last Post: 7th May 2008, 14:44
