Results 1 to 10 of 13
Thread: Fault code P0301 on 3.2 HELP?
    Regular Member jamesr's Avatar
    Lancashire
    Default Fault code P0301 on 3.2 HELP?
    I have got the code 0301 - Cylinder 1 misfire.
    The car runs REALLY rough, at idle and when driving really missing and juddering - will not go much above 20mph?
    Yet flick to LPG and its perfect!
    So i was thinking maybe its an injector/fuel prob as this is the only part that is used on petrol everything. else would be common to LPG or gas?
    Any ideas what could be causing this?
    HELP!
    Regular Member 900ss's Avatar
    May 2008
    Bucks
    Quote Originally Posted by jamesr View Post
    If it runs fine on gas it cant be mechanical?
    So would try the plug 1st then change the coil or injector
    Check the injector loom aswell whilst your at it?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    As the LPG will have an injector emulator, then it will probably be the injector or conections etc. Unlikely to be coil if it runs well, but having 5 other cylinders could mask the effect of it.
    Lancashire
    Tried everything and its still the same.
    That's both our family cars playin up!!
    I need it fixed by tomorrow cos back to work on Tuesday
    reading
    test the feed on injector plug to make sure its pulsing i use a led to test it. then if you cannot remove the injector may be best to check it with a meter
    Lancashire
    So connect -ive lead to earth and +ive of LED to the wire going into the injector?
    reading
    test first by connecting led to both wires on injector plug the led should pulse with engine running , if not then need to test each wire in turn should usually be switched on a - with a ign + on most cars
    Lancashire
    Iam pretty sure that the injector plus on the V6 are buried deep under the inlet manifold so will not be that easy to test directly?
    reading
    yes they are not great to get to but guess you gotta start somewhere to try and sort it. I have a spare set of v6 injectors
    Lancashire
    Yes but not sure how to get at them, with engine running? you can get at them with the "lid" off the induction but not with engine running?
  1. Fault code help
    By RBH in forum Engine & Drivetrain
    Last Post: 16th December 2012, 22:46
  2. Fault Code help
    By MiniVauxhall in forum Engine & Drivetrain
    Last Post: 17th May 2012, 10:04
  3. fault code help
    By jpbroad1970 in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2012, 19:26
  4. Fault code help :(
    By Thom in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2012, 20:14
  5. P0301 code only and V6 3.0cdti
    By med09 in forum Engine & Drivetrain
    Last Post: 1st April 2011, 18:01
vectra c 3.2 v6 misfire cylinder 1
vectra 2.6 v6 fault code p0301
vectra 3.0 cdti error p0301
vauxhall vectra bfault codes 0301
