Results 1 to 10 of 11
Thread: Fitting new turbo to cdti 150hp
    SUSSEX
    Question Fitting new turbo to cdti 150hp
    Hi, I'm going to fit a new turbo to a 56 plate 150hp Vectra cdti, so wonder if anybody have got any tips, Do's and don'ts.
    Bo
    Cambridgeshire
    Is you current one broken?
    SUSSEX
    yes, 78000 miles, collected car from garage today. only thing there havent been replaced on this car is the stering wheel
    Belfast
    There's something about bleeding the oil through the turbo, not sure how it's done. I don't think it's a case of bolting on and starting up.
    Regular Member sri22dti's Avatar
    Northern Ireland
    I have a turbo and manifold with 3000 miles on it from an 2007 150cdti. PM me if you want it for a price
    Regular Member Craig1985's Avatar
    harwich essex
    just out of warranty then
    Regular Member benny's Avatar
    Feb 2006
    dudley
    replace the oil inlet banjo bolt it has a gauze filter that can block this is normally why the turbos fail ....also change the oil and filter ....
    SUSSEX
    Thanks, will start to pull the car apart over the weekend.
    SUSSEX
    Any tips on how to get oil to the turbo before I start the car up?
    Ashington, Northumberland
    Warm the engine up (i take it the car runs). do an oil and filter change first, but don't start the car after you've finished. Remove your old turbo. To prepare the new turbo, see if you can get hold of a syringe and top it up with engine oil (Garrett turbos come supplied with one), use this to gently introduce oil into the intake hole (not the oil return hole) whilst turning the turbo impeller. This 'primes' the turbo. Fit a new banjo as described above, or at least make sure it is spotlessly clean. Swap any parts over onto the new turbo and fit to the car. When you're done, start the car and make sure the oil pressure warning light goes out within a second or two. If it stays on, switch off and investigate why. Once running, let the car idle for 2 minutes without revving it up, whilst checking for oil leaks etc. If all's well, take her for a spin
  1. Tuning Box Chip Vauxhall Vectra C 1.9 CDTI 150hp
    By borderman932 in forum Vectra C / Signum Car Chat
    Last Post: 29th February 2012, 20:22
  2. tips for fitting a 2.2 dti turbo
    By peadar in forum Diesel Engine related
    Last Post: 27th February 2012, 00:20
  3. 1.9 cdti 150hp max power
    By darko2301 in forum Diesel Engine related
    Last Post: 11th January 2009, 14:28
  4. Fitting a saab turbo
    By icetrix in forum Petrol Engine related
    Last Post: 30th January 2008, 00:49
  5. Help needed fitting 2nd turbo
    By Inspektor in forum Comedy & Humour
    Last Post: 14th October 2005, 08:45
vauxhall turbo banjo bolt gauze filter removal
