Results 1 to 10 of 11
Thread: Vectra VXR Clutch
    spoons
    Guest
    Default Vectra VXR Clutch
    Can anyone on here confirm which clutch the Vauxhall Vectra VXR has.
    Specifically the 2007 280bhp model
    (I've been told that it may use a single mass flywheel clutch?)
    spoons
    Guest
    Just read this on honest John
    2007 model year versions of the Vectra VXR had power boosted from 255PS to 280PS, thanks to a redesigned induction system, modified engine components and retuned electronic engine control software. 0-60mphdown to 6.1 seconds for the hatchback and 6.3 seconds for the estate. Chassis also tweaked to give more dynamic handling. Modified spring and shock absorber settings and correspondingly retuned IDSPlus2 chassis control software is said to optimise the pitch, roll and turn-in characteristics to make the most of the increased performance without ruining the Vectra VXRs impressive refinement. The difference between the normal chassis setting and the Sport setting, which is activated by the dashboard-mounted Sport Switch, has been further increased. This engine sounds wonderful and the car is quite a good performance package.
    http://www.honestjohn.co.uk/carbycar/index.htm?md=526
    Got loads more data on the Vectra-C as well...
    Regular Member mic's Avatar
    Jun 2007
    Hope you don't need a new clutch before the MLR 30 - 130 What time do you think you will do it in and what top speed?
    Regular Member VectraV6CDTi's Avatar
    Wilts
    Quote Originally Posted by spoons View Post
    Nothing much on the 3.0 V6, apart from:
    3.0V6 CDTi Elite voted Caravan Club 'Family Towcar of the Year 2005.
    Great!!!
    Belfast
    A few inaccuracies in that review.
    spoons
    Guest
    Quote Originally Posted by mic View Post
    My clutch is fine thankfully...
    But as to times.... no idea... and no idea....
    I just hope I'm not last compared to the other cars
    Jun 2007
    You shouldn't be last cause their are three alfa's running, they will be lucky to get any where near 130 before they break down, and also a golf gti. Time wise I would of thought you should be in the low 30sec possible late 20 sec bracket. Top speed not sure either but best of luck you will have a great day.
    Regular Member Voxer's Avatar
    Ayrshire, Scotland
    If it's just normal Hot Hatches or normal cars(no supercars) then I would guess Spoons 'll be fairly high up the ranks, The Tuned Vec is in it's element on 30-130 run(30-100 should be around 12secs through the gears I think).
    Regular Member rosssri's Avatar
    S.Lanarkshire
    Sorry if you think i'm hijacking this thread but i was just wondering if you could help me out by offering your opinion.
    How reliable is the Vectra VXR?
    I'm seriously considering getting rid of my 55 plate cdti sri as it's developed numerous problems over the last 3 months. Luckily my warranty was still valid in December when the clutch and DMF had to be replaced.
    spoons
    Guest
    Quote Originally Posted by Voxer View Post
    Well, I can go from a standing start to 100 mph (proven at Santa Pod) in 14.3 seconds... so assuming it takes me 2.5 seconds to get to 30 mph (due to traction) then the remaining 12 seconds would be from 30-100. So as you say Voxer, around 12 seconds from 30 to 100... then I'm in 4th gear which pulls like 3rd gear... so how many seconds from 100 to 130 mph ?? - answer = dont know, as I've never timed it.
    I would guess at low to mid 20's from 30-130mph... which shouldnt be too bad (but I may be waaaaay to optimistic)
    Also, I've seen some of the cars I'm up against... and I dont think I'm gonna win somehow - lol
    Lambourghini LP640
    EVO VIII = 30-130 in 15.94 seconds
    EVO V GRS = 514 BHP and 470 Lb/ft
    EVO IX GT = 752 BHP and 662 Lb/ft
    EVO = 580 BHP and 478 Lb/ft
    EVO = 500 BHP and 490 Lb/ft
    EVO = 523 BHP and 30-130 in 10.1 seconds
    60 cars in total attending..... ... and I could be the slowest
    Quote Originally Posted by rosssri View Post
    Hasnt broke yet... 2 years old now
  1. Help. vectra c clutch problem
    By bucco in forum Engine & Drivetrain
    Last Post: 8th February 2013, 20:00
  2. vectra c clutch
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 17th August 2011, 21:04
  3. vectra c 2.2 sri clutch
    By francav in forum Engine & Drivetrain
    Last Post: 14th June 2011, 20:50
  4. Vectra C 2.0 DTi Clutch HELP!
    By british_bulldog in forum Engine & Drivetrain
    Last Post: 15th October 2010, 20:39
  5. clutch kit for 2.0t vectra how much
    By stephen g in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2010, 11:32
vectra vxr 30-130
