Results 1 to 10 of 15
Thread: Brake Pads
    Regular Member ballogie's Avatar
    Scotland
    Default Brake Pads
    What would be considered a reasonable mileage to get out of front and rear pads on a Signum 1.9 ? Just normal driving with no heavy braking
    Scotland
    ok, I've had a search in the forum and it varys from 18000 to 83000 !!
    Regular Member sdemps's Avatar
    Nov 2007
    Ayrshire
    I just changed mine at 54k! They were the origionals!
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I changed rears at 75 and fronts at 78 from original. I had to change rears again at 103K as the spring cames off the caliper / carrier and caused uneven wear to one side.
    Apr 2006
    Suffolk
    Ive just replaced the original rear pads after 40,000 miles. There is one slight issue I have which is that the fronts are still the originals and I would have thought that the front pads would have worn out first due to weight being put over the front axle.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Most people find the rears wear first.
    Regular Member mark_w's Avatar
    cheshire
    Apr 2006
    Suffolk
    What causes it?
    Being a fully qualified car mechanic, I can't understand why the rears would wear out first before the fronts. They are both made out of the same material. The only difference is the front discs are vented and rears are solid.
    Regular Member rosssri's Avatar
    S.Lanarkshire
    I changed the front pads on my 55 plate cdti sri at 42000 miles (last month before its 1st MOT) as a large chunk of the pad lining was missing (don't know how that happened) and it's never had the rear pads changed as far as i know. I've had the car for nearly 2 1/2 years now.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Look at braking effort to pad contact area. Higher brake effort or smaller pad contact area will increase wear rate. The rears are considerably smaller than front pads. Obviously the fronts will have a much higher braking effect split, but maybe the brakes were designed to wear at similar rates (mine both wore out within 3K of each other (75k rear, 78k front)
  1. What brake pads for 2.8 V6 Signum??? 314mm brake discs
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:21
  2. brake pads
    By HEP in forum Handling & Braking
    Last Post: 17th October 2008, 23:32
  3. brake pads
    By johnnyg in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2008, 09:38
  4. brake pads
    By dwdwdw in forum Suspension, Wheels & Brakes
    Last Post: 5th September 2008, 10:25
  5. Brake Pads
    By phildews in forum Handling & Braking
    Last Post: 15th July 2007, 20:06
