Thread: Diesel - fuel pressure ?
    Regular Member Led's Avatar
    Kings Langley
    confused Diesel - fuel pressure ?
    Had the odd issue with my 54 plate 2.0 DTi, most recently was after a journey back from a trip away. Car was parked on level ground with 1/3 tank of fuel, I spent over 5 mins trying to get it to start , AA man spent another 60mins and said I'd need relaying home - great I thought at £97 to join - I wasn't a member.
    I waited another couple of minutes - turned the key and brum, the car sparked into life
    The car has played up 2 or 3 times before - usually when left 2 weeks or when parked facing up hill.
    When it was serviced just last October, the injector seals and bleed off lines where both checked and deemed OK the usual diagnosis for this kind of problem.
    Q's
    Could the fuel pump (in the fuel tank) become lazy (give low pressure) ?
    Is there any way in checking the fuel pressure (or what it should be).
    Is there a non-return valve in the pump or can one be fitted to the fuel line ?
    I've had the car from new and it's now covered just 41K - just want to sort out this starting issue when left for more than 4 days or when parked up hill
    Regular Member rosssri's Avatar
    S.Lanarkshire
    My old vectra b 2.0dti had the same symptoms as this it turned out it was the diesel return pipes had become pourous which was causing the diesel to run back into the tank. Some days the car would start 1st turn of the key then the next it would just turn over and then fire up eventually.
    Hope this helps.
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    the 2.0 does not have a fuel pump in the tank,just the engine driven pump
    Belfast
    It's the fuel spill pipes. The AA man is a moron if he didn't know that.
    Kings Langley
    The AA man only did what his laptop told him
    So the only fuel pump is the one at front of the engine ? it doesn't have a seperate pump to prime the system ?
    It is the only problem/issue I have with the car - which is infuriating
    The 'fuel spill pipes' ??
    Borrowed pic from another thread.
    Full Member
    Bristol
    This is a common problem with this type of engine. Make sure you get the genuine VX leak off pipe and new t pieces, that sould cure you problem. Use fairy liquid to put pipes on t pieces as they break easy and leak off conections
    If for some reason it does not cure it then the injector seals are the problem and they are under the camshafts. Not a job for the faint harted
    I f for some reason
    Kent
    What is in the leak off pipes, something i would consider changing if I had a starting issue but do they contain fuel?
    Full Member
    Bristol
    Default leak off pipes
    Yes if you have starting problem if you are parked up for a while air get back to the pump and creates an air lock.
    Yes they carry the excess fuel back to the pump that is not used. This systenm is fitted to all diesels from the year dot when diesels were invented. Get some laytex gloves keep the dielsel of you hands its hard to get rid of the smell.
    Coke is a good thing. I was driving down the pacific coast Higway in California when a tanker went past leaking diesel it covered the windcreen. I pulled into a garage and asked if they had anything to get diesel of the windscreen and he said coke. It was brilliant now I pour it on my hands if I diesel on them.
    Kent
    so its not a case of removing the pipes and you empty your fuel tank
    Jan 2006
    carlisle
    Default leakoff
    get a one way valve from motor factors |(about £12) and fit it in the system at the engine end
    helps a lot
    i had the same on my 2.2dti
  1. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  2. diesel pressure sensor
    By chris167 in forum Engine & Drivetrain
    Last Post: 28th November 2010, 12:55
  3. V6 Diesel - fuel rail pressure issue
    By Phil in forum Engine & Drivetrain
    Last Post: 5th August 2009, 22:08
  4. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
  5. fuel pressure?
    By beefycol in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2007, 12:31
is there a diesel return pipe going to the tank in my Vectra 54 plate and is there a fuel pump in the tank
