Thread: gsi 3.2 auto box goosed
    New Member muller73's Avatar
    warrington
    Default gsi 3.2 auto box goosed
    last couple of weeks very snatchy gear change's next i got a spanner light on and then no gears(only 2nd and 5th in triptronic) so taken in to garage they said turbine speed sensor fault,so checked the gearbox oil and it looks like old black engine oil so i guess it's a new box got quotes for 1700 quid ****** hell i'm not askin then to put a man on the moon here!! anybody no of a good and cheep gearbox places in the liverpool/manchester area
    thanks
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Poves broke his 3.2 because the box went he has brought a Golf instead with some of the monies he made stripping down the 3.2. My autobox went last year luckily was covered under warranty. By the way they are £3200 from the stealers for a recon one!!
    Regular Member poves's Avatar
    lancashire
    Quote Originally Posted by muller73 View Post
    thanks
    option 1 - Change the atf fluid and sensors , fingers crossed .
    Option 2 - get a second hand box , bit risky as the ecu may not pair upto it , and it may go pete tonge like the original box as well after a few month.
    option 3 - break the car , then with the funds replace it with a motor with a manual box .
    I speak from experience , don't make the same mistake as me , and keep "wishin it fixed" it won't happen , move on and learn from the experience.
    They are uneconomical to repair given the value of these cars at the moment , nobody wants to touch the boxes with a bargepole .
    I know I may sound negative , but I've just been through all this the last 6 months .
    Good luck whichever way you decide to go .
    south wales
    looking for a vec very soon would love a auto but read so much negative feedback are they all bad
    lancashire
    Well , in my opinion anyone who buys an autobox after all the problems on here has one , or all of the following 3 things .
    1 - Bottomless wallet.
    2 - Super duper all singing all dancing warranty.
    3 - Brain damage .
    south wales
    i get the picture cheers mate
    Regular Member ccsnet's Avatar
    The local dealers if driving my old Vectra
    Quote Originally Posted by poves View Post
    3 - Brain damage .
    I'm on 2 but it aint worth the hassle.....
    Terran
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    thanks
    Muller - was this diagnosed at a VX stealer? If, and I'm not sure on this one, the turbine speed sensor is the same part as the input/output speed sensors, then VX are/were aware of a problem. Have pasted the following from a mate of mine at VX:
    Field Remedy: 1685
    Subject:AF23/33 transmission - Malfunction of automatic transmissionModels:Engines:Option:Vectra-C 2002...2004,Signum 2003...2004Z22SE| Z32SE| Y22DTR,Z22YH| Z32SE| Y22DTR| Y30DTAF23/33 TransmissionComplaint:No or incorrect shifting function. DTC P0700, P0715, P0720 (separate or together) stored.Cause:Faulty transmission input/output speed sensors signal due to moisture inside the sensor.Production:Grease application on speed sensor plug as of transmission No: 03MV735125 (06.January 2004).
    Remedy:
    In case of customer complaint install new sensor and apply grease on the sensor plug to avoid moisture ingress. If the failure reoccurs please also refer to TSB 1650.
    Part: Part-No.: Cataloge-No.:Grease 09163339 19 48 877Sensor 93173888 62 38 259
    Doesn't sound like you've water in the box, again see VX field remedy below:
    Field Remedy: 1650
    Subject:AF23/33 transmission - No driving torque because of cooling water in transmission oilModels:Engines:Option:Vectra-C 2002...2004,Signum 2003...2004Z22SE| Z32SE| Y22DTR,Z22YH| Z32SE| Y22DTRAF23/33 TransmissionComplaint:Loss of the transmission functionality in isolated cases. The following symptoms may occur occasionally: - failure codes P0700, P0715 or P0720 set - slight loss of cooling water - sediments in coolant expansion tankCause:Improper function of the sealring at the oil cooler conncetion. This can cause the penetration of a little quantity of cooling fluid into transmission oil.Production:An improved oil cooler/radiator has been introduced in production as of VIN W0L0ZCF3541042598 (Rüsselsheim) and VIN W0L0ZCF6848035197 (Ellesmereport).
    Remedy:
    In case of customer complaint proceed as follows:If only DTC P0700, P0715 or P0720 is stored please carry out TSB 1685. Open the black cover of the valve body on the transmission housing carefully. If water and/or white sediments are found in the cover the transmission has to be replaced together with the oil cooler/radiator assembly.
    According to the owners service book, VX say the auto box oil is changed every 40k miles or 4 years, whichever is sooner. This procedure is often overlooked by the Stealer - mine wasn't changed unit 65k miles and, although I didn't have your problems, the smoothness of the gear changes was much better with no clunking.
    I changed the oil on my GSi auto for £40, simple enough job to do.
    There are other threads on the forum with a similar problem to yours but I can't have a look at the moment (work calls).
    Hope the above helps before shelling out £1000's.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Found these threads http://www.vectra-c.com/forum/showth...highlight=auto
    Also you could do a forum search for "auto" in the technical/troubleshooting/engine&drivetrain sections.
  1. Is my CAT goosed?
    By pompey-pimp in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2013, 18:04
  2. someone please confrim my DMF is goosed
    By jamesb in forum Engine & Drivetrain
    Last Post: 22nd October 2012, 16:48
  3. DPF Goosed.......
    By signum_1.9 in forum Engine & Drivetrain
    Last Post: 27th July 2012, 13:43
  4. Is my DMF goosed
    By gibbon7000 in forum Engine & Drivetrain
    Last Post: 19th November 2011, 21:57
  5. goosed or not
    By andy76 in forum Engine & Drivetrain
    Last Post: 11th March 2011, 18:28
