Results 1 to 10 of 11
Thread: 314mm brakes question
    Regular Member Super T's Avatar
    May 2007
    On the Levels
    Default 314mm brakes question
    When fitting 314mm brakes do you have to fit new back plates and do they comewith the kit.
    Tyneside
    No back plates needed mate, the Saab kits come with them, but you don't need to fit them.
    Going by the following posts do you mean the useless plates already fitted or the proper plates that go around the whole disc like on the rears?
    Either way nothing needs changed, just get a screwdriver between the disc and plate and bend it out a lot as stones have a habit of getting stuck causing a high pitched squeal.
    Regular Member davree's Avatar
    Warton
    Vehicle : Insignia
    Engine : 2.0 CDTI (160)
    Year : 2010
    Mileage : 26000
    I think they might come with the kit!
    Someone will probably correct me though!!
    Regular Member poves's Avatar
    lancashire
    Best and cheapest option to buy second hand , your backplates just need a bit of a " clearance tweek "
    Warton
    Vehicle : Insignia
    Year : 2010
    Mileage : 26000
    Quote Originally Posted by mark1319 View Post
    Not sure if they can be fitted either.
    Beat me to it
    May 2007
    On the Levels
    Thanks lads.
    Regular Member sberrow's Avatar
    Newport (Gwent)
    you finnaly got hem brakes then Super t
    May 2007
    On the Levels
    No but im trying!! if i can find some to buy cos i've cleared it with the boss
    Newport (Gwent)
    my misus said there should be the Car Owners Wife club, but she should rethink the title
    Cambridgeshire
    Quote Originally Posted by sberrow View Post
    very good
  1. 314mm brakes...
    By danBoy in forum Handling & Braking
    Last Post: 3rd September 2014, 22:04
  2. 314mm Brakes
    By s1nglef1sh in forum Handling & Braking
    Last Post: 31st December 2008, 17:31
  3. 314mm brakes
    By chrisgettings in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2008, 22:37
