Thread: 5 speed Vs 6 speed
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    Default 5 speed Vs 6 speed
    What is the 6 speed gearbox on the VXR like?
    I was wondering if the 6sp is generally better or worse than the 5?
    On cold mornings from 1st to 2nd can get quite bad with the 5 speed box on my Direct and sometimes crunches.
    Cambridgeshire
    I have no problems with my 6 spd. Although mines a diesel. ( I don't know if this makes a difference?)
    Regular Member Dippy-Vx-line Red's Avatar
    Earlston (Scottish Borders)
    Hi i have a 6 speed diesel and its fine but only when the car heats up after a couple of miles...Usually when cold 1st - 2nd can crunch sometimes but as i said when warmed up it`s a grear gearbox..
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Quote Originally Posted by BigP View Post
    There is a VX field remedy for that mate.
    Regular Member mark_w's Avatar
    cheshire
    my 5sp doesn't crunch, but it's a bit snickety snick notchy sometimes. what's a field remedy?
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by mark_w View Post
    This only applies if the hydraulics have been bled and the cables are adjusted correctly.
    Field Remedy: 1653
    In case of customer complaint the sliding gear has to be replaced by using the Repair Kit, Partno.: 9201451 / Catalogno.: 16 07 013. There is no need to replace the entire transmission.
    Regular Member shippers's Avatar
    Jun 2007
    driffield
    I find my 6 speed a little lumpy mostly 1 -2 worse on cold mornings.
    Regular Member MalcGSI's Avatar
    E Sussex & Kent
    Think most of them do it to some degree.
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    my 1.9cdti does not crunch in any gear (unless i forget to push the clutch down lol) but i do find the change very slightly notchy in that you do feel a slight resistance when you put the car in gear or change gear,never had a problem selecting a gear
    Apr 2006
    Cheers for the replies guys, so generally it can be a little notchy till warm, same as mine really.
    I have been to the dealers with the FR printout Rushy but it doesn't apply to my car, not in the right build range or something.
    Its not a major problem, just a bit annoying sometimes on really cold mornings. It may be going soon anyway if I get lucky.
  1. 5-speed gearbox on 6-speed z22yh
    By Ant SRi in forum Vectra C / Signum Car Chat
    Last Post: 17th April 2012, 09:06
  2. Speed limits & speed cameras.
    By kentish_bloke in forum General Chat
    Last Post: 15th February 2010, 21:22
  3. Z22YH 5 speed or 6 speed
    By caigey in forum Vectra C / Signum Car Chat
    Last Post: 18th August 2009, 11:56
  4. 5 speed / 6 speed gearbox difference?
    By electron in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2007, 21:27
  5. Speed Camera's / Mobile speed traps M6>M61
    By suj786 in forum General Chat
    Last Post: 10th March 2006, 22:38
