Right need to know what sensors are where and if i need i new loom or will the plugs be there already but taped up
Cheers guys
Cheers guys
??? Check what?
Plugs for what?
Check control system
Tells you when your washer fluid is low,brake fluid,engine oil,bulbs are blown
There are sensors on washer bottle and i think brake fluid not sure what else,i just need to know what they look like and what the plug looks like
** = Check control warning display features engine oil
level, engine coolant level, automatic transmission
control (where fitted), front brake pad wear, windscreen
washer fluid level, bulb test for head/tail and brake
lights, and brake lights fuse. Trip computer features
instantaneous and average fuel consumption, fuel
consumed, average speed, distance travelled and range
based on fuel remaining.
Might be that they all have it fitted as standard but ive never ever had a warning light come on about washer fluid
Is there any way of checking the spec of my car to see if this was all fitted ?
disconnect the plug at the bottom of the coolant resovoir or take out a bulb somewhere - should see a pic of a radiator or bulb on the display. From what I've seen Check control can either be a basic system which uses the display in the rev-counter (where you see door open or EML), or more advanced using the GID/CID.
Basic systems don't appear to have all sensors like washer fluid level, but do have bulb failure, coolant level etc. In a basic system the Bulb failure is also basic - Bulb and exclamation mark (not which bulb), the more advanced use of GID/CID tells you which bulb to check (LEFT BRAKE etc).
Had my Trip computer activated by the dealer, and it automatically turned on check control. however without a sensor on the washer bottle the display kept saying check washer level. Dealer then decided to disable the check control feature. I'm left with the basic option - display on the rev counter.
My 04 LS has all them (and I've had most of them come on) except, I don't the washer fluid level sensor.
Coolant low
Oil low
brake warning
bulb warnings
