Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: Check control
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    67 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Default Check control
    Right need to know what sensors are where and if i need i new loom or will the plugs be there already but taped up
    Cheers guys
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    ??? Check what?
    Northampton, UK
    Plugs for what?
    Quote Originally Posted by n_hudson View Post
    Plugs for what?
    Quote Originally Posted by Ste View Post
    ??? Check what?
    .... confused, could be the sea air....
    Devon
    67 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Check control system
    Tells you when your washer fluid is low,brake fluid,engine oil,bulbs are blown
    There are sensors on washer bottle and i think brake fluid not sure what else,i just need to know what they look like and what the plug looks like
    [Ex]Admin Duncan's Avatar
    Yours hasn't go that?! Blimey, what spec is it? - thought it was on all the models?
    Devon
    67 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Lol Duncan its an LS it has some check control but as far as i'm a ware not all models had the check control for washer fluid and some other things.
    or should i just sit down and shut up i might be wrong
    Devon
    67 Post(s)
    Vehicle : insignia
    Trim : irmscher
    ** = Check control warning display features engine oil
    level, engine coolant level, automatic transmission
    control (where fitted), front brake pad wear, windscreen
    washer fluid level, bulb test for head/tail and brake
    lights, and brake lights fuse. Trip computer features
    instantaneous and average fuel consumption, fuel
    consumed, average speed, distance travelled and range
    based on fuel remaining.
    Might be that they all have it fitted as standard but ive never ever had a warning light come on about washer fluid
    Is there any way of checking the spec of my car to see if this was all fitted ?
    Regular Member LJ sxi-nav's Avatar
    Winchester
    disconnect the plug at the bottom of the coolant resovoir or take out a bulb somewhere - should see a pic of a radiator or bulb on the display. From what I've seen Check control can either be a basic system which uses the display in the rev-counter (where you see door open or EML), or more advanced using the GID/CID.
    Basic systems don't appear to have all sensors like washer fluid level, but do have bulb failure, coolant level etc. In a basic system the Bulb failure is also basic - Bulb and exclamation mark (not which bulb), the more advanced use of GID/CID tells you which bulb to check (LEFT BRAKE etc).
    Had my Trip computer activated by the dealer, and it automatically turned on check control. however without a sensor on the washer bottle the display kept saying check washer level. Dealer then decided to disable the check control feature. I'm left with the basic option - display on the rev counter.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    My 04 LS has all them (and I've had most of them come on) except, I don't the washer fluid level sensor.
    Coolant low
    Oil low
    brake warning
    bulb warnings
  1. Check Control Fog Lights
    By any-mgzt in forum Electrical & ICE (including SatNav)
    Last Post: 14th February 2013, 15:39
  2. Check control system
    By bertxuk in forum Vectra C / Signum Car Chat
    Last Post: 3rd May 2012, 10:09
  3. Strange HID and check control?
    By yysnet in forum Electrical & ICE (including SatNav)
    Last Post: 8th September 2010, 19:51
  4. Facelift SRi Check Control
    By joejdx in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2010, 21:42
  5. Check Control?
    By JonR in forum General Chat
    Last Post: 3rd February 2007, 00:36
