Thread: Amp power/earth from boot
    South East
    Default Amp power/earth from boot
    Hi,
    On the left (N/S) of my boot inside a compartment there is power to lots of fuses, some high rated. Q, can I take the power/earth for an amp from any of these, not after HIFI quality sound.
    M
    Feb 2006
    Dorset
    For safteys sake go to the battery , never tap off of any other systems in a car for high current drain equipment like amplifiers etc .
    Regular Member Ian's Avatar
    York
    Quote Originally Posted by DennisTheMenace
    completely agree. If you add say 30amps load to a high amps wire, then you may overload the wire cuasing lots of heat, which may ,melt the insulation and then set fire to the car!
    For new high current circuits like an amp, run direct from the battery with a fuse at each end of the wire.
    Battery mate for power and anywhere below rear seats for earth..
    South East
    cheers guys
    M
    Regular Member Robward27's Avatar
    Witham
    Pretty easy to do, easier than i thought ran mine down passenger side under sills. It can go through wiring loom grommet in passenger footwell.
  1. Connections on Travel assistant (Power/earth etc)
    Last Post: 14th May 2011, 15:10
  2. power and earth
    By dilan in forum Vectra C / Signum Car Chat
    Last Post: 30th September 2010, 17:17
  3. No power to boot lock
    By bnam in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2008, 12:57
  4. power in boot
    By middler31 in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2008, 18:57
  5. Earth connection in boot
    By Ian T in forum Electrical & ICE (including SatNav)
    Last Post: 2nd May 2007, 02:39
