Page 1 of 6 123 ... LastLast
Results 1 to 10 of 55
Thread: 1.9CDTi Intake Manifold/Flapper Valve ESSENTIAL INFO
    Regular Member Phil MC's Avatar
    Kirkie
    Thumbs up 1.9CDTi Intake Manifold/Flapper Valve ESSENTIAL INFO
    Just found this little Service Information Leaflet from Pierburg, the manufacturer of the Z19DTH intake manifold. I'd advise you print and keep it, wether you presently have a fault or not.
    http://www.ms-motor-service.com/xima...093_en_web.pdf
    Hope this helps some of you who experience Low power problems, and keeps you away from the extortionate dealers as much as possible .
    Good luck,
    Phil
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Thats an excellent bit of information.
    I gives people more of an idea of whats required should their car have a swirl valve/inlet manifold issue.
    Doesn't really help those with physical problems etc.. but provides much needed information.
    Apr 2008
    SOMERSET
    Default no rail
    hi
    my car is running fine, no lights on,good mpg, goes like a rocket,
    BUT that rail thing that links up the swirl valves is not there at all !!
    had the car for 14/15 months now and only looked after reading so much about on this site.
    any advise please
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by BRIANE View Post
    hi
    any advise please
    If there is no rail, then there is no control over the swirl valves, this can mean that they could close completely, this would certainly give you a problem in running.
    You 100% certain its not there..?
    Apr 2008
    SOMERSET
    Hi mate
    deffo not,will have another look in morn but i have seen it on another car cause the bar should keep rocking from side to side.
    Have done prob 12000 miles since i got it.
    If i had n,t looked on this site would n,t even had know about it.
    Have already done the 3rd injector plug thing,
    Belfast
    any advise please
    You've actually got a 120PS engine.
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by _ZS_ View Post
    He said it goes like a rocket though...
    (sorry, couldn't resist )
    Regular Member vockycdti's Avatar
    May 2007
    stoke
    i had this problem on mine too....all good now tho. thanks for the info
    Apr 2008
    SOMERSET
    No deff a 150 cdti sri 2004
    Kirkie
    Default Flapper valve bar?
    That's exactly the same model/year as mine and it should have the flapper valve bar connecting the four flapper valve spiggots together because it's just the 3rd from left valve that is powered and the rest are mechanically slaved.
    Do you at least have the four circular plastic top covers with the spiggots sticking up?
  1. For Sale: Intake Manifold
    By neill in forum Parts for sale
    Last Post: 20th September 2012, 14:36
  2. Video Renewing 1.9CDTi Cambelt & Intake Manifold - Interesting
    By john506 in forum Engine & Drivetrain
    Last Post: 31st August 2011, 16:11
  3. Replies: 3
    Last Post: 30th March 2011, 09:31
  4. Is there a how2 for removing the intake manifold on a 1.9cdti
    By Gavin2.6 in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2010, 22:49
  5. Intake Manifold Valve 1
    By Adamant in forum Engine & Drivetrain
    Last Post: 21st August 2007, 20:13
