Thread: 1.9 CDTI intake airflow problem
    Regular Member muctm's Avatar
    Mar 2007
    on the milky way
    Default 1.9 CDTI intake airflow problem
    Hy all.
    I've done some test runs with the car and OPEL SCANER and I thinck something is not right:
    pick-up from 2-nd gear
    acc from 2-nd gear and changed 3-rd
    3-rd and then changed to 4-th
    the blue line is the air intake sensor.
    Why does it fluctuate like that?
    red line is accelerator pedal
    green is EGR comand 100% -> closed
    black is torque sensor
    Mar 2007
    on the milky way
    confused
    BUMP.
    Still don't know why that happens
    EVERYWHERE
    Do you have a K&N filter fitted?
    Is your air filter clean?
    Maybe they all do that! ?
    Mar 2007
    on the milky way
    The air filter is a mann-filter paper and it's clean.
    Even if they all do that it's not normal..maybe we can improve something
    EVERYWHERE
    You could run the same tests using different filters or even no filter,different intakes,no intakes,no filter box,larger filter box,cooler air,warmer air,no mesh grilles on the MAF etc,etc,etc.
    You could then maybe have a straight line where once there was a squiggly line,but you may still not notice any difference in the way the car drives!
    Mar 2007
    on the milky way
    I'll do some more runs when it gets warm outside and let you know if I get anyware...
  1. CDTI 120 Intake flap
    By Jackvectra18 in forum Engine & Drivetrain
    Last Post: 15th June 2011, 21:13
  2. Intake air Sys Leak 1.9 CDTI
    By TonyTM in forum Engine & Drivetrain
    Last Post: 5th May 2010, 20:20
  3. Vec C Cdti (150) Airflow Meter
    By DeanF in forum Parts for sale
    Last Post: 25th June 2009, 22:34
  4. Airflow/intake shotening
    By DTGB in forum Petrol Engine related
    Last Post: 25th August 2008, 21:00
  5. air intake cdti 150
    By chrisgettings in forum Diesel Engine related
    Last Post: 3rd February 2008, 02:49
