Just Put A Sri Bumper And Fog Lights On My Car And I Need Some Help. Do I Need To Take It To Vauxhall For Them To Program The System So The Fog Lights Will Work Or Will The Work When I Put The Switch In ???????????
hi mate there was a thread about this but im sure it has to be tech 2
I think it has to be "tech 2" enabled too.
YEP it defo does, believe me...
Yes I know Micky "armoured farmer" is right, he had a bit of a game with a set of front spots.
Just A Quick Up Date.took Car To Vauxhall To Let Them Turn The Fog Lights On With Tech 2 And After 3 Hours They Told Me They Couldnt Do It As You Supposedly Cant Fit Fog Lights After The Car Has Left The Factory Because Tech 2 Cant Talk To The Ecus Properly.
Any More Help Please
Originally Posted by rob CDTI
reqiures a new ECU, so i was told...However a decent auto electrician can wire them into a seperate switch..
Is That What You Did If So Did You Put A Seperate Switch In And Where Or Did You Like Me Spend £40 On A Proper Switch With Front And Rear Fogs On It?
Bought the loom,4 button switch, fog lights..NO JOY..VX useless.
Sold the car to my bruv (Pioneer), who is gettin an Auto electrician to run new wires, via a relay and fuse to a switch below the TC button, so it doesn't look out of place.
Thanks For That And I Do Agree Vx Are Not Very Helpfull Considering They Built The Car.
Cheers For That
