Thread: Does anyone have a K&N?
    Regular Member Ean's Avatar
    Suffolk
    Talking Does anyone have a K&N?
    Hi all,
    Does anyone actually use a K&N cone on thier 2.2 Direct?
    I have seen and heard loads of people going, 'oh no, no, no...'
    I just wondered if anyone actually had success?
    I am going to try one this weekend, going to build a heat sheild too, to go between engine and the K&N.
    Also get a cold feed pipe to it, or extend the cone down to hearer to the bottom of th car as possible!
    What are peoples thoughts on that bit? Either get a longer cold air pipe to it? Or put it lower to the ground?
    Cheers for now,
    Ian.
    Regular Member falco's Avatar
    Jun 2007
    Cockermouth
    Yes I have a K&N 57i on mine with a heatshield and cold air feed.
    I used too have a panel filter with the air box mod and wasn't overly impressed. But with the induction kit the car pulls much better than it ever did.
    East Scotland Regional Organiser signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    K&N here buts its not 2.2 direct felt my standard box filter could not cope with remap ..but this is brilliant pic below
    Suffolk
    See, my Air flow mass metery thingy is at the front of the engine.
    Bottom left hand corer from the vx badge on the cover....
    Jun 2007
    Cockermouth
    Yep same as mine.
    Regular Member Marty 1888's Avatar
    Scotland
    Can any of you guys advise me on an induction kit for the 2.0T? Easy to fit is the idea!!
    Jun 2007
    Cockermouth
    The k&n took me no more than 10 mins to fit, the hatdest part was removing the old airbox.
    Suffolk
    DONE MINE!
    K&N Cone. Fitted. Works a treat!
    little bit of trottle, some succking noises....give it BIG throttle, and you get a real throaty groan and sucking noise! :-)
    Revv's free'r, gear changes both down and up on theauto box are better too!
    Whoop!
    2.2 direct btw! :-)
    Regular Member bertbuckie1's Avatar
    Turriff - Aberdeenshire
    is that what a k&n looks like for a signum 2.2 signumboy? or has it been modified with the metal outer shield ? ( hopefully mine is here tomorow along with the erst of the stuff i ordered lol )
    Regular Member Ben999's Avatar
    Milton keynes
    I have a k&n induction kit on my 2.2 SRI. Notice very little difference in power, consumption, gear changes or throttle. However this means it doesnt cause any problems.... Oh..... and it sounds LUSH!
vectra c 2.2 direct cone k&n
