Results 1 to 2 of 2
Thread: Suspension & Steering Noises
    Leeds
    Default Suspension & Steering Noises
    Hi
    My 53/04 2.0T has developed an array of noises! The first was a clunk from the nearside front wheel which turned out to be a suspension joint. Kwik Fit replaced this, though it required a whole new lower suspension arm and was about £150. This did get rid of the clunking on that side.
    Since then, I've noticed a definite clunk, quite a harsh metallic clunk when going over speed bumps. Seems to be mainly from the driver's side.
    There is also a crunching noise when I go over speed bumps too, accompanying the metallic clunk.
    In addition, there's a low level, constant rumbling sound at any speed above about 20 mph. It's quiet, but noticeable.
    Also, occasionally when I steer, especially when accelerating, or reversing off a driveway, I get a clunk. On the MOT it said there was slight play in the steering rack knuckle joint. Does anyone know how big a job this is to fix?
    Any advice on the clunking, crunching and steering rack knuckle joint would be very gratefully received!
    Best regards,
    Phil
    Jul 2006
    Mexico
    Many Vec suffer from noises in the front suspension do to the lack of spring seats.....there is a "spring seat mod" which you add a pair of rubber sleeves to the front coils...works well.
    The joints that you mention I recommend to take it to a mech...unless you have the tools and want to get you hands dirty
  1. Knocking in suspension / steering.
    By lh_4827 in forum Suspension, Wheels & Brakes
    Last Post: 11th January 2013, 21:48
  2. Suspension noises!! Newbie needs some help!!
    By Adgti in forum Suspension, Wheels & Brakes
    Last Post: 23rd October 2012, 23:46
  3. Quick help needed - Suspension noises after fitting FKs!
    By Leemarksmith in forum Suspension, Wheels & Brakes
    Last Post: 27th June 2012, 18:08
  4. Suspension / Steering
    By moneypit in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2011, 19:31
  5. suspension noises
    By john-d in forum Handling & Braking
    Last Post: 11th May 2010, 20:22
