Results 1 to 10 of 18
Thread: Something strange happening
    Regular Member cdms811's Avatar
    Newcastle
    Default Something strange happening
    Hi,
    I am having an intermittent problem (or problems) with my 05 plate 2.2 Direct. Firstly, very occasionally on acceleration the car seems to mis a beat. Best comparisson I can make is back to when I had a plug fail on my very old astra. It is very occasional though. The spanner has been known to come on when this has happened but it doesn't appear to be storing any fault codes.
    Next
    On a run down the A1 the other week this happened again, however, the spanner light went out after a few mins to be replaced by the emissions light. The car at this point started chugging, bit like having kangaroo petrol lol.
    Stopped, restart engine, all is fine and NO stored fault code.
    Help!
    Ps I have no EGR valve. The stealers removed it a while back when it had issues and it was replaced with a blanking plate
    Maida Vale
    Hi Mate, sounds like you've had (or tried) to have the codes read. Was that by a pro or one of those chinese £35 code reading boxes?
    Codes aside, an easy first attempt to fix it is to change the plugs.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Sorry mate, sounds like the High Pressure Fuel pump/regulator problem mate. Not cheap if out of warranty, although with all the fuss kicked off about it on Watchdog you may get a good deal.
    Regular Member izonoky's Avatar
    Aug 2007
    London
    Had the same problem, engine ticks over and seems to subtly miss a beat, easy to miss if you're not the observant type. But deffo - High Pressure Fuel pump / regulator is about to fail. When it fails you'll know. You'll loose all power and the car will coast a stop. If your in town you'll be ok, but if you're cruising or about to overtake on the motorway...very scary.
    I had mine replaced under warranty, personally I think there should be a recall. It's the only real chink in what's considered to be a great engine.
    Newcastle
    Well, broke down on the A1 and had to be towed home (120 miles) by the AA! .
    Fault codes are Cylinder 1 misfire, Cylinder 2 misfire. Diagnosed as Coil pack
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by cdms811 View Post
    Well thats good then mate, cheep as chips compared to Fuel pump and Reg.
    Oct 2006
    Wellingborough
    Interesting, i had this at the weekend on mine, once when full throttle in third, and again full throttle in second on a slip road. feels like a misfire, but on both occasions power was fine afterward and no fault lights.
    Don't fancy a motorway breakdown, will the stealers do anything to check the fuel pump with no stored code (car still in warranty and only done 23k!)
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    Quote Originally Posted by Flaninacupboard View Post
    dought they will do anything m8 as there is not a problem to show them
    Oct 2006
    Wellingborough
    That's what i figured, no light=no problem to them. no toher check they could do, i.e. output pressure from the fuel pump?
    Newcastle
    If its the same as mine you will eventually get an spanner showing, which soon disappears to be replaced by emission light. Car will appear not to have stored any code (ie no spanner at ignition)
  1. Strange Happening or not !
    By Hypographamist in forum Vectra C / Signum Car Chat
    Last Post: 7th October 2010, 16:15
  2. This can't be happening!
    By Birchy63 in forum The 'Off Topic' room
    Last Post: 20th April 2009, 19:16
  3. Something strange happening
    By Ean in forum Engine & Drivetrain
    Last Post: 9th February 2009, 17:36
  4. Do we Have an RO yet??.... and is anything happening??
    By VinnyPeewee in forum North Wales (RO - vacant, ARO vacant)
    Last Post: 4th November 2008, 00:20
  5. Much is happening here!
    By 10PEL in forum International Region
    Last Post: 6th April 2007, 10:16
