Results 1 to 10 of 11
Thread: Rear spring removal
    Regular Member s1nglef1sh's Avatar
    Fife - Scotland
    Default Rear spring removal
    Don't know if I'm missing something but here goes...
    Tried to remove the rear springs the other day to help while replacing rear arms, arb bushes etc.
    Wheel off, supported car on frame, trolley jack under lower arm to take weight off suspension, jacked up to compress whilst applying spring compressors.....when I let the jack down nothing happened...ie couldn't get the spring off....
    What am I doing wrong?
    Ashington, Northumberland
    You don't need spring compressors for a start. do what you were doing before with the trolley jack under the arm, but remove the bolt that holds it onto the hub (E18 torx socket). Now slowly let the jack down and remove it. Put your hand on top of the brake disc and push down, the spring will fall out.
    Fife - Scotland
    Oh, how come I don't need spring compressors?
    Quote Originally Posted by GARY3306 View Post
    Sorry for sounding stoopid...Would that be the bolt holding the lower control arm onto the hub?
    Also, should I be marking the exact way the spring was held in before?
    Thanks in advance
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by s1nglef1sh View Post
    Because the lower control arm will drop enough to let the spring be removed. On the fronts it's different and so they need to be compressed.
    Yep.
    No need.
    So did you not remove the spring when you were trying to do the upper control arm? (I thought you said you had?). You'll definitely find the access to that inner bolt so much easier by removing the spring.
    Fife - Scotland
    Not yet Duncan, no. We didn't manage to get the spring off so that's probably why we struggled so much with the control arm. We're gearing up for another crack on Sunday so I can go into this weekend armed with your good advice as always!
    Regular Member bgm46's Avatar
    South Queensferry
    mate if you want to borrow my Haynes manual (for quick ref) then let me know
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    you cant go wrong with this m8
    Fife - Scotland
    Quote Originally Posted by bgm46 View Post
    Thanks mate, I've already got one and was using it on Sunday I was probably looking in the wrong place knowing me...
    South Queensferry
    promise i am not laughing
    Fife - Scotland
    lol
  1. 314mm brake pad removal spring
    By DHobbs in forum Suspension, Wheels & Brakes
    Last Post: 8th January 2012, 00:19
  2. Front Spring Removal Question
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2011, 01:46
  3. rear spring removal
    By colashbury in forum Suspension, Wheels & Brakes
    Last Post: 25th June 2010, 20:37
  4. 2 Front SRi / 1 Rear Sri / 1 Rear Ls Spring
    By jordib in forum Parts for sale
    Last Post: 16th May 2010, 20:21
  5. Rear Spring Removal? Help?
    By mototrain in forum Suspension, Wheels & Brakes
    Last Post: 9th March 2009, 23:58
vectra c rear spring removal
