Thread: Vectra Weight
    Plymouth
    Default Vectra Weight
    Had a search on the forums... no luck..
    I dont have my manual with me... so cant check there.
    Soooo,,
    Does anyone know what the weight of the Vectra 2.0 Dti.
    Need to know as im looking at getting some axel stands.... and need to know if i need to get 2 tonne or 3 tonne..... and im a tight arse and dont wanna spend more than i need to.
    Regular Member mace's Avatar
    Jan 2008
    Wiltshire
    2 ton'll do ya unless you've got a boot full of sand of course!
    Plymouth
    Quote Originally Posted by mace View Post
    Better make sure the misses is outta the car when i get it up on the stands then lol
    Jan 2008
    Wiltshire
    Seriously though, heaviest Vectra in the book is the 3.0 V6 cdti estate auto at 1661 kg(kerb weight), while the lightest is a 1.8 exclusive manual hatchback at 1335kg so its a pretty safe bet your DTi is somewhere in this range. Been checking tyre pressures so manual is in arms reach
    Plymouth
    Heaviest Vectra in the book is the 3.0 V6 cdti estate auto at 1661 kg, while the lightest is a 1.8 hatchback at 1335kg so its a safe bet a DTi is somewhere in this range. Been checking tyre pressures so manual is in arms reach
    cheers mate...
    will go get the 2 tonne axel stands for £15
    Regular Member david.aka.judas's Avatar
    Suffolk
    1505 to 1525kg for the hatchback.
    1580 to 1600kg for the estate
    Plymouth
    Cheers Judas
    Suffolk
    np - m8
  1. weight
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2012, 13:39
  2. Weight of Vectra CDTi 150
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2011, 22:44
  3. Scissor Jack for Vectra - Max Weight?
    By Innes in forum General Chat
    Last Post: 31st March 2011, 17:35
  4. Vectra Z20NET Axle Weight?
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 26th December 2010, 18:05
  5. best way to put on weight.
    By Dose in forum The 'Off Topic' room
    Last Post: 1st December 2009, 17:59
how heavy is a vectra c
how many ton does a vectra weigh
how much in tons does a vauxhall vectra weigh
vectra c gearbox weight
weight of a vectra
how much does a vauxhall vectra c weigh
vectra c weight
weight in kg for vectra c
