Thread: window washer not working
    Regular Member VECTRA HEAD's Avatar
    Derry
    Default window washer not working
    Advice needed guys if possible,since the cold snap has been upon us my washers has failed to work,the pump sounds as though it has power going to it.A few weeks ago i added some cheap screenwash and i am thinking that this may be a factor to my problem.Has anyone else had this problem?
    Sunny Dartmoor
    Not me personally,but read a few threads on this,get the bottle out and give it along with the pump and hoses a good clean,that should sort it out.........
    Derry
    if i do get it sorted,it will be water only from now on.
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Funny how "the cold snap" has come and they stopped working.
    Just a guess here, but could they be frozen?!
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I only use water, have heated jets and it doesn't freeze.
    Derry
    wudn`t mind having the heated jets fitted also,did you fit them yourself?
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Yes, 15 minutes and about £10 from dealer. There's some info on here, inc part numbers. If you use the search button above you will find more than you will ever need
  1. washer jets -NOT WORKING!
    By nim-nim in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2011, 18:52
  2. Washer Not Working
    By Hollingsworth87 in forum Electrical & ICE (including SatNav)
    Last Post: 17th August 2011, 15:15
  3. window washer jets not working
    By steve-wolves in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2011, 13:43
  4. Back window washer not working...
    By Stevie-B in forum Bodywork & Interior
    Last Post: 2nd April 2007, 08:59
  5. Help, my rear washer isn't working
    Last Post: 9th July 2006, 10:51
