Results 1 to 10 of 14
Thread: How much for rear shocks...
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Default How much for rear shocks...
    just found out nsr is fooooked so how much should i expect to pay for a new one? spose it would be better to replace the pair?
    Belfast
    Definately replace the pair. Go to Euro Car Parts and get a pair of Bilstein B4's - they're about £20 each and considerably better than the rubbish Vauxhall will sell you.
    ECP import Bilstein to the UK, so are cheap.
    Newcastle under Lyme
    Will these work on a Vectra 1.8i 08 reg facelift if I want to lower it?
    Regular Member bigboynigs's Avatar
    Oct 2007
    ALDERSHOT
    depends how much you want to lower it by as to whether you need to upgrade the shocks.
    yes the bilsteins are best to get if you're going to upgrade.
    i'd say most of the guys on here have them fitted ( i know i have )
    Belfast
    B4 are the direct replacement to the standard shocks. Ideally, you'd want B6 or B8 if you're lowering - they're the "sport" shocks and are designed for lowered cars.
    From Balance Motorsports page:
    B6 or B8 Sprint?
    B6 - Ideal upgrade for standard dampers, all the benefits of B8, designed to work with standard ride height and up to 30mm lowering.
    B8 - Specially designed for lowered sport vehicles. It’s a must when sports springs are used
    with lowering of 30-40 mm or more. Shortened unit gives less droop and more predictable control of over/undesteer and sharper responses. (In some cases only B6 will be listed.)
    Regular Member adfrodsham's Avatar
    lincoln
    ive got the bilstiens, perfect no problems, but check as they are model (eg sri, gsi) specific
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    its a 2.2 petrol sri.
    Nicking Ya Dinner.
    Yeah, don't put VX ones on, they are rubbish, leaking is their weak point, and it can happen at any time, inspector I know failed a brand new one for leaks.
    Bradford
    Trim : Elite Auto
    Engine : 2.2 Direct Petrol
    Hi
    Had a look on eurocarparts.com for the Bilstein B4 - couldnt find them listed for a Vectra. Does anyone have the part numbers?
    Also - how much would a local garage typically charge to replace shockers on both sides?
    Regular Member ShauneDTi's Avatar
    Ammanford area
    I need replacement rear shocks on my SRi too, just contacted Eurocarparts and have been quoted £31.95 + vat each for Bilsteins
  1. Rear Shocks
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 24th June 2010, 10:50
  2. Rear Shocks...
    By macdad in forum Suspension, Wheels & Brakes
    Last Post: 25th March 2008, 13:04
  3. Rear Shocks
    By Big Sig in forum Suspension, Wheels & Brakes
    Last Post: 9th July 2007, 21:37
  4. Rear shocks-gas or oil?
    By storey_3000 in forum Vectra C / Signum Car Chat
    Last Post: 27th August 2006, 11:33
