Thread: Airbox Question...
    Northampton, UK
    Default Airbox Question...
    Can anyone tell me how "loose" the airbox is in their car. Had a little play today and noticed the airbox moves a heck of a lot and the rubber bushes(?) do little to hold it still, so it just bumps around when pushed...
    Also, when the car is accelerating, how much would this cause the airbox to wobble? Is it put under any strain or pressure that would cause it to "wobble" freely?
    I've had a look in my mums and my GF's car, and the airbox is mounted firmly to the car, no movement at all.
    Any ideas or suggestions? Thanks!
    Merseyside
    Shouldnt move at all IMO - take it to the stealers if its in warranty and get new rubber bushes put on it.
    Regular Member shan's Avatar
    Mine is mounted quite solid on the rubber mounts. No movement at all if you give it a push. Bit of a pain when i pulled it out to do the air intake pipe and filter mod.
    Are you sure all the rubber mounts are in the mount holder's correct.
    Northampton, UK
    No, she's out of warranty. I'll just go and order some. At least that settles that one...
    But does anyone know how much stress the airbox is put under during acceleration? If it was poorly held, would it wobble around?
    It should be under no stress at all as the two connect's have a flex connect on them.
    Northampton, UK
    Quote Originally Posted by shan View Post
    Yep, there's a longish shaped one underneath, a horizontal one on the right and a vertical one on the left. (As you look at the car from the front to rear) So 3 in all. They just seem really loose.
  1. i just went outside to do the airbox mod and...
    By rockafella8587 in forum Diesel Engine related
    Last Post: 4th February 2012, 15:44
  2. Airbox mod.....part deux!!! (rip off of VXR280 airbox mod)
    By paul_sri150 in forum Diesel Engine related
    Last Post: 30th January 2012, 22:50
  3. Airbox question
    By swifty_53 in forum Diesel Engine related
    Last Post: 2nd March 2011, 20:55
  4. Airbox question
    By Graeme01 in forum Engine & Drivetrain
    Last Post: 21st March 2010, 11:16
  5. Airbox mod
    By tank in forum Petrol Engine related
    Last Post: 12th September 2006, 13:00
