Results 1 to 10 of 27
Thread: 18 pin to 32 pin
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Default 18 pin to 32 pin
    Need the help of some one with a degree in electrics
    Ive looked at this site HERE and there's a wiring diagram that tells you what pins from a 18 pin plug to swap over to a 32 pin plug,would anyone with a wiring diagram of both plugs be able to look at them and tell me what wires are what and tell me what wires on the 18 pin goto the 32 pin for sure.
    If i follow the guide on that site it means swapping 12 wires from an 18 pin plug which leaves me 6 wires left ! are these six wires swap like for like ?
    Any help would be grateful and i will post pics and a how to when its all wired in
    Regards Don
    Northampton
    Engine : A20DTH
    Mileage : 88000
    What are you trying to do?
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    I'm fitting a GID screen into my car mate I have a crappy TID at the moment that is a 18 pin plug the GID is 32 pin plug
    I know all it will be is a big TID screen but i will try and get a NCDC after a while or a ccr2006
    So i need to know what wires are what so i can just scotchlok them from the 32 pin to the 18 pin
    Northampton
    Engine : A20DTH
    Mileage : 88000
    You can pull the plugs out of the 18 and insert them into the 32. Much easier than scotchlocks
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    I know but i will more than likely forget what's what and mess it up this way if i scotchlok i can just use my old plug again and tape the other one up if it don't work
    Didnt you change your TID to a GID before Lee ?
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Well i think me might be all right as the 18 pin plug should only have 12 wires (Cheers lee ) will let you all know how i get on
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Anyone know what colour the wire is on the 18 pin plug pin 17 ?
    Regular Member blakewp's Avatar
    huddersfield
    dont know if this is any help to you, but i just removed my TID which had a 32 pin connector on, and plugged my GID straight in.
    Wonder if your TID has an option on the board to fit 32pin or 18 pin sockets - if thats the case you can probly follow it on the board.
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Any chance you could look at your plug and write down wire colours to what pin numbers ?
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    are you gonna be doing a how2 for this m8 would be very handy
    edit: hmm maybee I should read the first post through before asking
18 pin to 32 pin opel
vauxhall 18 to 32 pin
vauxhall tid 32 pin to 18
connector 32 pin vectra c
upgrading to 32 pin gid screen vectra
