Thread: Warranty about to expire/MOT Due
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Default Warranty about to expire/MOT Due
    My car is about to turn 3 years old and we all know that means no more warranty and its first MOT..
    So...
    What can I do to make sure everything that needs to be done on the car gets done before the warranty expires.
    I was thinking of taking it to a local MOT station and ask the inspector to more than usually thorough, but that probably won't catch any potential engine issues?
    also, I have 2 potential issues:
    1) I have had to to up with water a few times this year and I'm not sure if that's a sign of a potential leak somewhere or just normal?
    2) When in neutral and I lift my foot of the clutch I can hear the engine change sound at a certain point, I can really feel anything so I'm not sure if that's normal or not.
    Suggestions welcome
    Aberdeen
    Good question lofty, I am in the same boat as you, my veccy is due its first MOT in March along with the expired warrenty.
    I shall be watching this thread with intrest.
    Jan 2006
    Norfolk
    Quote Originally Posted by lofty View Post
    So...
    Suggestions welcome
    What gearbox does it have, I have just had my 2006 Auto box replaced under warranty after I had to put coolant in it several times, there is also a problem with some header tanks that seen to weep when hot, had that changed under warranty to. The auto box had some indication of water in the transmission fluid.
    I would get Vx to check it for coolant loss before the warranty runs out.
    Maida Vale
    When you take your foot off the clutch and the engine note changes - are you sure it's the engine you can hear, rather than the dual mass flywheel? If it is the DMF, I believe that's a sign that it's on the way out.
  1. Does power steering fluid expire?!
    By Chip in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2013, 14:48
  2. Warranty Direct or AA Warranty
    Last Post: 20th March 2010, 12:31
  3. ABS Under Warranty?
    By andi_york in forum Suspension, Wheels & Brakes
    Last Post: 24th February 2010, 09:55
  4. warranty
    By toughmat in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2010, 00:11
  5. Stealerships...warranty or no warranty, that is the question!
    By David_SRi_2.2DTi in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2007, 15:48
