Thread: Battery life
    Thatcham, Berkshire
    Default Battery life
    Does anyone elses battery go flat when the cars not been used for 2/3 days?
    The battery is only about a year old, and will stay fully charged for quite a while if I don't lock it using the fob - and if it's used on a daily basis.
    Have checked the alternator and it's suppyling enough feed to the battery... it's a 2005 1.9 CDTi 150phs
    Any thoughts?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    It sounds like you have a drain on the battery that shouldn't be there.
    The only way for you to find out is to check it out with a multimeter that does amps too.
    Basically open bonnet and hold the bonnet switch down with tape of something.
    lock car with fob
    remove the neg strap from the battery and place meter across battery and earth strap (alarm may go off and need resetting with fob, do it when meter is connected)
    Measure current
    If it is above about 100 milli amps then you need to remove the fuses to see when the current drain drops, that will identify the circuit responsibile for the drain.
    Then you may want to investigate further.
    Thatcham, Berkshire
    Excellent thanks - any ideas which fuses control the alarm / immobiliser as I am sure this is the problem.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    There's a full list posted somewhere on here, by me - a quick search - -
    http://www.vectra-c.com/forum/showth...highlight=fuse
    Thatcham, Berkshire
    Again thanks - so F11 does the central locking, alarm and immobiliser?
  1. battery wiring block next to battery 150tdci - HELP
    By jameslunt in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2012, 07:19
  2. Battery Light ON - 14.1 volts at battery
    By snapsnap in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 13:55
  3. Battery light on, 14.4V at the battery!
    By Saulty in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2011, 23:29
  4. Battery life
    By corm in forum Electrical & ICE (including SatNav)
    Last Post: 23rd December 2010, 20:04
  5. i saved the life of a life gaurd:)
    By the fisherman in forum General Chat
    Last Post: 26th September 2010, 21:25
