Results 1 to 10 of 14
Thread: Headlight Condensation
    Jun 2007
    Mold
    Default Headlight Condensation
    Anyone know how to get rid of condensation that is forming in my XP headlights?
    Vauxhall do not want to know! Even if under warranty!
    Regular Member vockycdti's Avatar
    May 2007
    stoke
    i have the same in my headlights....i hate it, just had my mot and the tester said as long as it doesn't affect the light its ok.
    to remove the condensation i don't think you can permanently without replacing the unit..... but for a quick fix you can use a hair dryer.
    also with headlights on it clears up.
    hope this helps a bit.
    Jun 2007
    Mold
    Default annoying
    right pain i know
    want to have a look at how to improve the seals as it just must be a break in a seal or something not quite right.
    any ideas people?
    May 2007
    stoke
    yeah it is a seal problem see it on alot of vx cars vx don't want to know like you said...
    hope you get it sorted mate, i just live with it arrrrrrrrrrr
    Regular Member arkhan78's Avatar
    Nov 2007
    Leeds
    bit of work but i took mine off and put them in a wardrobe for a couple of days refitted last year and never had a problem again...but it does leave your car stranded for a few days
    May 2007
    stoke
    are they easy to split without cracking the lense mate?
    Liverpool
    i have the same problem, what i did was get a packet of silica gel and put that in the back of the light. The problem has now gone. If this does come back i will just pop a new one in, hope this helps.
    WGAF#5
    they will need removing and drying properly as per the silica gel - very good and cheap idea.
    turning your lights on works like a kettle - heats up the water- turns into vapor and eventually when cold returns to its normal state -condensation returns !!
    be careful not to overheat if you use a hairdryer - you couls melt the seals and subsequently they will leak even more !
    Regular Member hibbsy18's Avatar
    May 2008
    Cambridgeshire
    Yes very very annoying. Best thing I've ever done is to remove the headlight take off all the covers an remove all bulbs, empty any water out and leave it on top of your engine when its hot! Works great!! Close the bonnet so your light doesnt fall and crack, because that would be even more annoying!!!
    Regular Member G.T.S's Avatar
    Helsinki
    In my lights i take the back panels off and putted the high beams on so it will take 5-10mins and they are clear! i don't ever have the back plates on anymore!
  1. Headlight condensation
    By jamiedvvt in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2013, 13:25
  2. Condensation in headlight
    By shamus5178 in forum Bodywork & Interior
    Last Post: 13th June 2009, 19:23
  3. Condensation in Headlight
    By cornishpirate in forum Vectra C / Signum Car Chat
    Last Post: 18th March 2008, 15:48
  4. condensation in headlight
    By johnny kebab in forum General Chat
    Last Post: 11th October 2007, 17:10
  5. Condensation in Headlight!
    By Robbie in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2007, 17:11
