Results 1 to 2 of 2
Thread: '06 Vectra indicator replacement
    West Lothian
    confused '06 Vectra indicator replacement
    First post on this forum, but am astounded that I can't (easily) replace the passenger side indicator lamp on my 06 SRI. The "turn signal lamp" fault appears on the dash display around 90% of the time, with intermittent spells when the indicator works fine. There has been some condensation in the headlamp casing for a few months (depending on weather it can sometimes be pretty much clear). Now I'm taking a wild guess, but I think the connection for the indicator is probably corroded and needs some cleaning. What I desperately need is help as I'm told the bumper needs to come off before I can even think about getting into the light housing.
    Jan 2010
    EK
    I'm also getting this problem with my SRI. I'm getting it on the drivers side front indicator and with the "turn signal lamp" on my display. I had this problem in July 2009 but after turning the indicator it went away. I thought i had it fixed but the problem returned just before xmas and it has never went away. I've lifted the air filter out but you still can't get into the indicator bulb. I've been told that i should maybe try a new indicator holder but just to get into it i will probably have to take the bumper off. It could also be a problem from a computer which is situated next to fuses around the battery. I can at least get my hands into the indicator but the passengers side is impossible to get into.
  1. Left indicator flashing fast, front indicator not working
    By Hummelshøj in forum Electrical & ICE (including SatNav)
    Last Post: 25th June 2012, 21:13
  2. Front Indicator won't work (Vectra C)
    By shauntaylor in forum Electrical & ICE (including SatNav)
    Last Post: 26th February 2011, 15:12
  3. vectra facelift indicator bulb
    By matt450 in forum Electrical & ICE (including SatNav)
    Last Post: 20th January 2011, 21:40
  4. vectra c 05 2.0dti indicator fault
    By cavie in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2011, 17:49
  5. vectra c indicator fault please help
    By SRIDAN in forum Electrical & ICE (including SatNav)
    Last Post: 29th March 2010, 22:13
Tags for this Thread
