Results 1 to 10 of 16
Thread: false boot floor
    Regular Member sristeven1's Avatar
    wirral
    Default false boot floor
    ok guys this might be a daft question but how do i make a false boot floor in my vectra i want to use it to install subs and amps in so i can still have the use of the whole boot from prams and stuff i no it will have to be coverd in perspex to protect the subs just wanted any info if poss on how to do the floor thanks all
    North Wales
    do you want the amps to be underneath the floor or is mounted on top ok ???
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    The way i done it in my cav and senator when i had them was i took the boot carpet out and used that as a template to cut out some MDF as a base to mount the subs on then i used battening round the edge and in the middle to support hardboard cut out the same shape covered in carpet.
    Regular Member alzsxi's Avatar
    Maidstone, Kent
    18mm MDF, use the boot carpet as a template, just cut it smaller otherwise it won't fit. Then it depends how you want to mount everything, I would mount the sub box underneath into the spare wheel well with the amp/amps on top and then another panel to go over it with either a cutout or fan for cooling.
    Maidstone, Kent
    Quote Originally Posted by Daywalker View Post
    You beat me to it!
    Regular Member SRIsteven's Avatar
    wirral
    yer i want to mount the subs and amps underneath it as i still need to be able to use the full boot for my daughters pram so the amp and subs wont get damaged
    North Wales
    ye best of using your spare wheel well and like the other comments say use your boot carpet as a template.. and just go form there u will need c cooling fan tho to stop your amp from over heating
    Regular Member Robward27's Avatar
    Witham
    Got a false floor in mine used original carpet and made it slightly smaller. Fun putting in but it does fit in one go but you have to take out the parcel shelf can post pics up if wanted currently runs 2x15" subs which just fit in lol. Then to make top section do slightly bigger.
    playing with spanners
    Quote Originally Posted by Robward27 View Post
    can i have some pictures please mate
    Witham
    Will take some tomorrow mate
  1. Please help me find a thread.... 2x 12" subs / false floor + access to spare wheel =)
    By Rosco88 in forum Electrical & ICE (including SatNav)
    Last Post: 28th May 2012, 20:45
  2. water in boot floor???
    By richiem in forum Bodywork & Interior
    Last Post: 18th November 2011, 11:38
  3. 'Dimples' in vectra boot floor
    By m111kan in forum Vectra C / Signum Car Chat
    Last Post: 5th May 2010, 13:26
