Thread: Changing Fuel Filter
    Regular Member CDTi-SRi-Matt's Avatar
    Nottingham
    Default Changing Fuel Filter
    Does anybody know how to do this think mine needs doing as my car stinks of petrol.
    Guide please anyone?
    Matt
    Glasgow
    If you smell petrol you may have a leak somewhere
    If it was showing signs of needing changed it would'nt run properly
    Nottingham
    What do you mean by not run properly?
    I doubt ive caught anything because the day i started smelling it id only gone round the corner to the shop when it was thick with snow, so i was driving carefully anyway.
    Doubt there was any chance at all of catching anything to cause a leak!
    Matt
    Glasgow
    Ahhh it will be the cold weather, your probably smelling it from the exhaust.
    When i say not running properly im meaning possibly feel it hesitating when you accelarate / a bit sluggish / or a rough idle. But it id put it down to the cold weather with the motor putting more fuel in to put the idle speed up.
    Nottingham
    Right i'll see what happens when the weather warms up abit then and the snow melts away!
    Its also in for a service soon so this may sort it yeh?
    Cheers for the help pal
    Regular Member willoftoon's Avatar
    FOREST HALL NEWCASTLE ,,,,,OR DECKHAM ,, ON SUNDAYS .. DINNER TIME MAMMY,S
    is it true they are in rear wheel arch somewhere
    Glasgow
    Honestly my friend its the norm the now, it gets very cold and more fuel goes in if you take a walk round to the exhaust you'll smell fuel (dont buzz to much of it lol).
    It will go away as the temperature pics up and the engine has less work to do on idle.
    P.S Its only just started snowing again up here in sunny scotland and its quite heavy does'nt look good
    Regular Member davree's Avatar
    Warton
    Vehicle : Insignia
    Engine : 2.0 CDTI (160)
    Year : 2010
    Mileage : 26000
    Yep its normal, mine is the same at the moment!!
    Willoftoon: I think it is about 6 inches forward of the rear driver side wheel.
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    Yes the fuel filter is attached to the fuel tank about 12" in front of the drives side rear wheel. When/if you change it fit new clips at the time as the old ones will most probable not fit to well and may leak.
  1. HELP!! after changing fuel filter
    By williamM in forum Engine & Drivetrain
    Last Post: 30th December 2010, 17:49
  2. changing the fuel filter on a DTI
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2009, 12:30
  3. Changing Fuel Filter
    By Sean-2.2Direct in forum Engine & Drivetrain
    Last Post: 22nd April 2009, 10:21
  4. Changing Fuel Filter
    By davieboy1976 in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2009, 11:41
  5. changing the fuel filter?
    By arkhan78 in forum Engine & Drivetrain
    Last Post: 21st December 2008, 17:10
