Results 1 to 3 of 3
Thread: Estate 1.9 CDTI Dual Exhaust - how ?
    Regular Member baard's Avatar
    Norway
    Default Estate 1.9 CDTI Dual Exhaust - how ?
    Does anyone have a recipe or a suggestion for how to fit dual Exhaust on a Vectra C Estate SRI XP2, with parking sensor’s ?
    I have seen Maverick’s brilliant way of “How to fit dual Exhaust on a Signum", and I have search the forum without finding how to do a similar job on my Estate ?
    Best Regards Baard
    Leicester
    The Signum and Vectra Estate use the same exhaust set up at the back, the due to the Signum's shorter overhang at the back it has shorter tailpipes.
    You should be able to fit the Vectra 3.0 CDTi estate rear silencer assembly straight on.
    The Vectra rear silencer assembly will however come with the drooper tailpipes and not the exposed pipes, as only the VXR estate has exposed pipes. This is an easy thing to change though, just have the droopers cut off and new tailpipes fitted.
    Your parking sensors will not be effected, and a decent exhaust place should be ablet o mount new exposed tailpipes showing under the rear skirt.
    You could fit the VXR estate exhaust bumper trim in place of the XP2 version as it already comes with cut outs for the exhausts.
    But my Signum how to should be pretty much the same for Vectra as far as the exhaust swap is concerned.
    Norway
    Thanks a lot. Do you know if the exhaust mod will inflate negative on the engine, or on the diesel consumption in any way ?
  1. estate dual exhaust
    By Swedge in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2012, 09:43
  2. Replies: 11
    Last Post: 9th December 2010, 17:42
  3. cdti dual exhaust parts.
    By michael cummings in forum Vectra C / Signum Car Chat
    Last Post: 3rd June 2009, 17:37
  4. Magnex dual exit exhaust onto cdti 150?
    By tom_p_2000 in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2009, 14:26
