Thread: clunks and pings
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : Insignia
    Trim : SE
    Engine : 2.0
    Year : 2011
    Default clunks and pings
    since the lil snow started im having very funny noises comeing from the nearside wheel it pings and small clunk sounds when i go over small speed bump and grates in the road and when i turn right, but big clunks over big speed bumps now the strange bit sometimes i get no noises at all but a strange kind of tapping like somthing is dangling and hitting the wing.
    yesterday it was really bad with the noises it is getting worse but this morning nothing not a single sound. ive looked under the wheel arch theres nothing i can see no snapped spring no leaking damper no bend arms that i can see.
    any ideas cant afford a garage bill so it will be a DIY job so ill need to be pretty 100% certain wot the noises are b4 i buy the parts needed to fix it.
    Regular Member craigbarlow18's Avatar
    Staffordshire (used to be Newark) And Back to Newark again!!
    I have the same ever since snow, makes like a twanging noise on taking up drive forward or reverse and on turning wheel, After a bit of research I think It might be the spring seat problem
    May 2006
    scotland
    Has the ice melted since? The reason I ask, in severly icey weather, my present car and many that I have owned in the past seem to squeak and groan a lot more. Wait till the weather gets a bit milder and if the noises decrease then you have something to worry about.
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    try the drop links mate? they are about 20 quid a pair and are worth doing if they havent been done before!! but if its still doing it it could be the mod on the spring needs doing
    Regular Member baard's Avatar
    Norway
    I just had the same problem with my car, on the right front side. Sometimes the sound was so bad that it sounded as if the spring was broke, when i drove over big holes or speed bumps in the road.
    It is now fixed at my local Opel Garage. It was the front upper spring bearing. (I hope you understand what i mean/my "norwegian -english").
    The mechanic told me that this was a common problem..
    mine seems to have shut up now its warmer
    Regular Member Driver0069's Avatar
    Oct 2009
    South Yorkshire
    Yes mine was doing the same first only some times and the it sounds like you just broke a spring
    when i turn the wheel i could hear bang bang so today got it in the garage and having the upper bearing done the garage has said it is ok now so i am on my way collect.
    Regular Member old cruiser's Avatar
    slough
    Quote Originally Posted by Driver0069 View Post
    is it sorted now mate?
    Cheers Pete
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Get this on a regular basis as i live in an area where quite a few of the roads have been top coated with chips!, every time i get this its ALWAYS chips getting trapped under the springs, they make weird noises from clunks to boings etc.
  1. Clunks when starting
    By mishima in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd February 2010, 17:08
  2. Clunks from rear of car
    By Angelchops in forum Suspension, Wheels & Brakes
    Last Post: 5th May 2009, 11:08
  3. Suspension 'Clunks'
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 3rd January 2008, 15:17
  4. Suspension 'clunks' when cold. Anyone got any knowledge.
    By andrewp3883 in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2007, 23:30
vectra c spring pinging
