Results 1 to 10 of 14
Thread: 302mm brake discs on a Signum.
    Regular Member shadow's Avatar
    Mar 2007
    Rotherham
    Default 302mm brake discs on a Signum.
    Hi folks
    Does anyone know if 302mm discs will fit on the front of my Signum cdti 1.9 150. I think the standard ones that are on are 285mm, so that would only mean a radious difference of 8.5mm. MY discs are worn and i`ve seen some 302s going cheap.
    Thanks in advance.
    Cambridgeshire
    You will need new calipers, carriers and pads as well if you want 302 discs. Sorry
    Unless you found 302mm kit going for a song, you may as well get the 314mm kit. I upgraded my 302mm kit on my 2.0T to 314mm and it made a big difference - so on a car with 285mm kit it'll make a helluva difference!
    Cambridgeshire
    It most certainly can as i have found
    Mar 2007
    Rotherham
    Thanks for that chaps. I will put the extra to and go for the LMF 314mm upgrade kit then, cheers.
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    Might be worth you ringing round some saab dealers as when they do brake conversions they have from time to time 314mm brake sets for £150 approx iirc as some members on here have done it.
    Mar 2007
    Rotherham
    Quote Originally Posted by Daywalker View Post
    Hi Daywalker
    I have seen some mention of these before on here. Will I still then require some extra brackets or caliper hangers as I think they are called.
    Cheers.
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    They do the whole lot together carriers,calipers,discs and pads
    Maida Vale
    Good idea in theory, but in practice you'll find they've all gone, unless a dealer has done a Hirsch brake conversion in the last couple of weeks (and dealers are having enough trouble selling new cars at the moment, let alone then convincing the customer that the 314mm brakes aren't up to the job and they should pay circa £1100 for the Hirsch brake upgrade). I got a set a few weeks ago by emailing all the Saab dealers in the country, in alphabetical order. I got down to V (Viking Saab) before an "S" dealer replied and said they had a set. The only others who said they had some were Brindley Saab in Wolverhampton, who have 4 sets, but their service manager reckoned they're worth much much more than £150 each. It may be worth seeing if they've got their heads out of the clouds yet, but don't hold your breath.
    Mar 2007
    Rotherham
    Quote Originally Posted by Thomas1 View Post
    Well thats commitment for you . Have you got yours fitted yet.
  1. Which discs? 280/302mm?
    By AlexGSi2000 in forum Suspension, Wheels & Brakes
    Last Post: 14th July 2011, 10:21
  2. 302mm front brake discs and pads quote £221 + Vat
    By Caveman_nige in forum Handling & Braking
    Last Post: 6th March 2010, 18:33
  3. What brake pads for 2.8 V6 Signum??? 314mm brake discs
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:21
  4. 302mm Discs and pads..
    By danBoy in forum Parts for sale
    Last Post: 15th June 2008, 14:01
