Results 1 to 10 of 18
Thread: Head light adjustment and AFL question.
    Regular Member shippers's Avatar
    Jun 2007
    driffield
    Default Head light adjustment and AFL question.
    I have noticed that my headlights are now only shinning about 12 feet into the distance making night driving awkward to say the least.
    Now I was lead to believe that my car has AFL but I now do not think it has, could any parts have failed so the AFL does not work at all if so is there any way of visualy checking to see if it has AFL.
    Can the lights be altered to shine further even if it has got AFL.
    Thanks in advance.
    On a Sabbatical daviek's Avatar
    ayrshire scotland
    If your lights have a blue ring around the dipped beam and they swing from side to side they are AFL's, they also have an extra bulb in the headlight unit and indicator lenses is more squarer
    Jun 2007
    driffield
    would I get a warning light on the dash if the AFL was not working?
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    Yes, you would get an AFL warning light on the dash but looking at you're sig pic you just have the standard xenons.
    This is what the AFL's look like. Notice the blue ring around the dipped beam, the smaller ''cornering light'' between dipped and main beam and also the rectangular indicators.
    Attachment 15944
    You could have a problem with the levelling sensors but i'd have thought that there would still be a warning light if that was the case.
    Jun 2007
    driffield
    Thanks for the info pricey.I was sold the car 2 years ago and the dealer told me it had afl I just thought it was rubbish lol.I really need to get the dipped beam headlights sorted as I have got a long night drive to do on thursday.Now i know it has not got afl can i adjust the lights manualy?
    Regular Member Matty H's Avatar
    Bristol
    AFLs
    <------- don't know if you can compare from my avatar pic
    Glasgow
    Mine is a pre-facelift, my zenons were really poor booked it in and turns out somehow the self levelling system was unplugged! Although it never put the warning up on the dash that it was faulty.
    When you turn on your headlights do they beams move up and down to level themselves??
    After getting the ecu re-connected they were still very low so i adjusted them myself using the adjusters on the top of the headlights and they are very impressive now without going to the extent of having other drivers flashing me.
    Bristol
    Quote Originally Posted by byebyeitsagsi View Post
    All xenon factory fit lights are self levelling. They have to be by law. AFL is completely different in that the lights move from left to right to when you tunr the steering wheel. It's so the lights shine around the corner you are turning into rather than directly in front of the car as normal.
    They take a bit of getting used to. Seems weird as first driving along and the lights are swivelling left to right as you turn. They are superb though
    Jun 2007
    driffield
    Yes the beams do move up and down when i put the lights on.I will get the took lit out tomorrow night and get them raised.
    Glasgow
    If there moving up and down then you know the self levelling is working, adjust the beams yourself best to do i against a wall or something so that you get them both on the same level take it for a spin and smile when you see the difference
    Just dont put them to high lol
    P.S I know what AFL is im just trying to give the guy some advice based on what ive found with my own motor.
  1. Question about turbocharger adjustment (Y22Dtr)
    By Z80 in forum Diesel Engine related
    Last Post: 22nd July 2012, 06:02
  2. head light question
    By dannyjpuk in forum Engine & Drivetrain
    Last Post: 17th November 2010, 19:45
  3. facelift head light question
    By glynn in forum Vectra C / Signum Car Chat
    Last Post: 9th August 2008, 12:18
  4. head light question
    Last Post: 9th May 2008, 23:17
  5. Front fog light adjustment
    By gtr1000 in forum Electrical & ICE (including SatNav)
    Last Post: 25th December 2007, 18:38
