Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: CDTi (150) EGR valve clean
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Default CDTi (150) EGR valve clean
    Hi,
    Is there a how to on the above? Just wanting to clean my egr out - and wondered how easy access to the egr etc is and if its a simple job?
    cheers
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Is it causing problems? I tried cleaning mine but found it much better just to replace it.
    Middlesex
    Trim : SRI
    Mileage : 100k
    slight lumpy idle when cold - and just want to rule it out tbh, but i know the egr can cause this...
    where is it located mate, and its it easy to access / take off / clean and put back?
    cheers
    Tain - Easter Ross
    As you look at the engine, its at the back of the head on the right side (passenger side).
    Very easy to take off but not as easy to clean. Mine was ****ed and even a good clean made no difference so just replaced it. If you are going to remove it, watch out for the metal gaskets - quite easy to drop and lose them down the back of the engine bay.
    Tain - Easter Ross
    so good I said it twice.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    You fancy cleaning mine ant??
    Cambridgeshire
    Quote Originally Posted by AntSSSS View Post
    Hi,
    cheers
    Here you go mate LINKY it's been talked about and sounds very easy. Was thinking of giving it a go myself. Good luck
    Regular Member Blagmeister's Avatar
    Warks
    I'm first to admit I am crud when it comes to spannering anything other than a Landrover which I can mend with a hammer. That having been said, I took off my EGR the other week and cleaned it and you should have seen the clag which came out of it!
    It has helped with removing a nasty little misfire I had. No sign of it since. I also took the battery lead off for half an hour to reset the ECU and I'm sure that has helped too.
    Follow the How To parsco posted a link to. It's a no-brainer.
    And you don't need a hammer either......
    Middlesex
    Trim : SRI
    Mileage : 100k
    lol - my labour rate is pretty fair mate hehe
    I think I am going to do this today then... looks easy
    A
    county durham
    sounds abit like mine have you had any power loss isuses and your engine light come on,
    also mine has abit of a rattle.
  1. will a egr valve clean help my mpg?
    By will-crowe in forum Engine & Drivetrain
    Last Post: 14th December 2012, 11:24
  2. clean the egr valve
    By dcdevlin in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2009, 21:24
  3. EGR Valve Clean-WHAT TO DO???
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 6th May 2009, 13:19
  4. Egr Valve Clean
    By GSiSnash in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2008, 09:17
  5. Can I clean my EGR valve?
    By Advocate in forum Engine & Drivetrain
    Last Post: 24th March 2008, 15:01
