Results 1 to 10 of 25
Thread: Satnav upgrade
    NULL
    Default Satnav upgrade
    Hi all,
    I currently have a 53 plate signum with a ncdc2013 satnav with full colour screen, Does anyone know if i can upgrade to the cd70 satnav? i have found one resonably priced with the screen.
    thanks
    James
    Northampton, UK
    I dont think so, its the canbus, half canbus issue... I asked the same Q a while ago. I'm sure its different connections etc. I'm sure someone else in the know will give you a better answer and more detail...
    Leicester
    It can't be done I'm afraid.
    NULL
    Are you all sure, as the ncdc 2013 is canbus, hence no code as it is all stored in the ecu.
    Regular Member MysteryElite's Avatar
    Feb 2007
    North Somerset
    The 2013 is coded to the car, but the difference is more that the age of cars with the 2013 are all "half" canbus whereas the CD70 type units were in the full canbus cars.
    The communications between the units, steering controls, screens etc are all different.
    Northampton, UK
    Quote Originally Posted by MysteryElite View Post
    Feb 2007
    North Somerset
    Quote Originally Posted by n_hudson View Post
    Oi! if you don't mind
    Northampton, UK
    DOH!!!! Sorry, totally missed that! I didnt have my glasses on...
    Leicester
    Quote Originally Posted by jamesworts View Post
    Quite Sure.
    Oct 2006
    Wellingborough
    i imagine you could get it to work, but there would be some issues, such as:
    your steering wheel controls would not work
    ignition logic would not work
    speed sensitive volume would not work
    tunnel driving from onboard speed/steering angle sensing would not work
    climate control (if fitted) would not function correctly
    fuel warning/plotting would not work
    plus some others i've probably not thought of.
  1. SATNAV CD upgrade
    By lgtuk in forum Electrical & ICE (including SatNav)
    Last Post: 5th June 2010, 15:39
  2. SatNav upgrade
    By TopRod in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2010, 21:59
  3. Radio to SatNav Upgrade
    By Ridgerider in forum Electrical & ICE (including SatNav)
    Last Post: 4th October 2007, 11:53
  4. satnav upgrade.
    By steve25v6 in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2007, 18:22
  5. Upgrade to SatNav?
    By VectraMat in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2006, 09:26
