Results 1 to 10 of 11
Thread: 3.0cdti tickover ????
    south shields
    Default 3.0cdti tickover ????
    Hi, i have recently bought a 2004 53 plate 3.0 cdti sri vectra auto..... until recently the idle has been approx 650 rpm, until the last couple of days it intermittantly keeps idling at abouy 825rpm. I know it not a massive leap but being the auto it makes it 'creep' alot more and snatch into gear sometimes from neutral. this only seems to have started since it got cold and i have noticed a strange pattern....if the onboard computer shows above 1.5 degrees it starts up and ticks over at 650 rpm, but under that the idle picks up and stays at 825 ish....even when the car is warm and been runnin for hours. no fault lights on dash and apart from that it drives fine, is this normal?
    Full Member Big Sig's Avatar
    My manual ticks over at 750ish. Not sure if the autos are different.
    This is quite a common report on Vauxhall cars; erratic idling
    Typically it is caused by a dirty EGR valve and is more common on high mileage cars
    However, in the 3.0 V6 CDTI this appears to occur when the engine is cold or after a long spell of running at speed
    Mine usually starts at about 800rpm, then falls to about 600rpm after about 3 minutes
    If I have been driving on the Motorway then come to a stop the revs are at about 600rpm, however as the coolant gauge starts to rise to about 95'C the revs increase slowly, after which the coolant temperature falls back to about 80'C and the revs return to normal
    Regular Member BIG NEIL's Avatar
    Oct 2007
    Back in Belfast!!!!
    wouldn't worry to much ,mine has been a bit like that since i bought it over a year ago think it could quite likely be the cold
    south shields
    ok will keep am eye on it see if it stops when the weather warms up. Doing the same now ......came out to work 2.5 c tick over 650 , went to garage came back out temp dropped to 0.5 tick over 825 !!
    Oct 2007
    Back in Belfast!!!!
    now question for you fella.what it like driving a 3.0 v6 cdti as a taxi how do you finthe fuel economy etc???? you don't see many about most taxi vectras i see are 1.9 cdti's.
    EVERYWHERE
    Quote Originally Posted by 3.0cdti-taxi View Post
    I think that there is a software update that cures this.Check with VX.
    south shields
    thanks will look into the update as for fuel 26mpg but not bothered as my last taxi was a impreza !!!
    Can I suggest you look at the coolant temperature, rather than the external temperature
    south shields
    coolant temp in 85 90 only changes when out temp 1 or below
  1. 2.0t tickover
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2013, 13:13
  2. Tickover RPM?
    By johnnylegs in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2011, 09:48
  3. Tickover
    By sri150 in forum Engine & Drivetrain
    Last Post: 26th June 2011, 18:47
  4. tickover
    By DX52 in forum Engine & Drivetrain
    Last Post: 17th June 2009, 20:57
  5. Tickover
    By ukdesigngroup in forum Vectra C / Signum Troubleshooting
    Last Post: 26th July 2006, 14:31
3.0 cdti tick over
